Results 1 to 3 of 3
Thread: brake grinding noise
    Regular Member li4m's Avatar
    west midlands
    Default brake grinding noise
    as above im getting a grinding noise not all the time just some times and it stops when i apply the brakes all the pads have plenty left on them and the disks seem fine to, just wondering if anyone else has had this problem??
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi L
    have you checked the inside pads for wear,if they are ok it could be a cover plate catching a disc,make sure they are all clear of disc's
    PRESTON
    does it do this the morning after you washed it the night before or overnite when the weather is damp?
    Fine rust will appear on the discs after they have been damp, this is normal and when you first set off, on the first or second application of the brakes, they self clean, thats when the grating is heard and then are fine. If its a squeal noise, then it is more likely the pad friction material. I understand that it is the modern materials used in pads and a certian amount of squeal is considered acceptable.
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  3. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  4. knocking / grinding noise
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2011, 23:51
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
