Thread: C diesel engines.
    Jul 2010
    Hampshire
    Default C diesel engines.
    Hi folks, looking at getting a diesel, probably the 2.2dti as I cant afford the 150 LOl. Can anyone confirm if the engine in the early C is the same as the one fitted to the vectra B (2.2dti) many thanks.
    Dave
    S.Shields (Newcastle)
    Yeah it is, odds and ends were slightly moddified to it, but the engine its self stayed the same..
    Jul 2010
    Hampshire
    Still cam chain rather than belt?
    Dave
    Yes it still uses a chain to drive the cam shaft.
    Jul 2010
    Hampshire
    Thank you.
    Regular Member Innes's Avatar
    Plymouth
    I've got a 2.2dti SRi and things to look out for in the engine bay that I have had issues with are the Turbo to Intercooler pipe and the vacuum/boost pipes.
    With the intercooler pipe I got a new silicone (instead of rubber) pipe off ebay for £50. Vauxhall don't sell the pipes individually, they wanted £120 for 4 other pipes!
    The vacuum/boost pipes are a hard plastic pipe that can crack or get nicks in them. The rubber connectors can also split. This causes the car to go into limp-home-mode. I replaced the pipes with silicone ones off ebay for £8 for 4 meters (although probably only needed 3m).
    Its also a good idea to clean the EGR and boost sensor every 6/12months but that applies to all the diesel models.
    Pictured below: New silcone intercooler pipe on the left and the red pipes are the new vacuum/boost pipes.
    Jul 2010
    Hampshire
    Thanks Innes, much appreciated.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Also to add that the DTi is a fairly solid lump
  1. VAG diesel engines?
    By Steven in forum The 'Off Topic' room
    Last Post: 25th November 2010, 08:58
  2. Millers 4 for Diesel engines
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 18:23
  3. Vauxhall approve bio diesel in their engines
    By neilshaw1980 in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2008, 13:28
  4. Diesel engines
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2007, 21:46
  5. diesel engines
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2007, 08:30
