Thread: Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    Jul 2010
    birmingham
    Default Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    Hi all
    First time post so no idea if its int he right place or not.
    My car (2004 1.9 cdti vectra c) has had black smoke coming out of it for a few weeks now. Knowing not alot about cars, i suspected it was in need of a service so, between changing the air filter and fuel filter myself and having the oil and filter changed at a garage, I hoped this would solve it.
    Apparently not. The smoke has got worse and the turbo is completely ineffective. Having had it back in the garage, there appears to be an air leak which has been traced to the very front of the car. If i Put my hand down the back of the bumper (in between the bumper and the radiator), i can feel air coming out when the engine is ticking over, more so when the throttle is pressed.
    any ideas what this could be? is it a case of a pipe having a crack in or something more serious?
    any help would be graetfully received!
    UK
    Default intercooler
    Hi
    That happened to me last year. It turned out to be a hole in the intercooler.
    If you take the front bumper off and slide a sheet of a4 paper between the rads you will be able to hear it and identify where it is coming from. If its the intercooler then the a4 sheet will proberly have oil on it.
    West
    As per other thread & above, most likely to be the intercooler
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Intercooler.... check through front grills for 'sagging' bottom of intercooler radiator.
  1. Replies: 19
    Last Post: 23rd April 2011, 11:51
  2. Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 29th July 2010, 13:51
  3. Vectra cdti 120 bhp. Air Leak? Turbo lagging?
    By colin IC in forum Diesel Engine related
    Last Post: 12th March 2010, 19:22
  4. 2004 Vectra CDTI 150 SRI Black VGC - £4250
    By tom_p_2000 in forum Cars for sale
    Last Post: 18th July 2009, 16:14
