Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: led daylights fitted
    Regular Member mccluskey119's Avatar
    gourock
    Default led daylights fitted
    hey guys fitted my led day lights into my fog surrounds today "jigsaws are great fun lol"
    wired to my side lights, but.. they flash when lights are off .. any adivce appreciated lol
    have a look at the pics n tell mi what you think
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    You will need a resistor putting in series with each LED strip.
    There are loads of threads about this.
    It is quite normal for LED's to strobe or flash in this way, due to insufficient resistance through the circuit.
    It may or may not also put up a bulb warning symbol on the small left-hand display in the dash panel...the one that tells you when the doors or boot are open along with other warning symbols.
    HID's have the same effect!!, they use a canceller for this.
    gourock
    think i'll try n source some resistors then , yeah i had the problem with the hids and got the canbus pro kit from hids direct , i wil need to take wiring n do it again anyway "make it abit neater lol thanks mate
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Hi mate
    what led set did you put in? (as i want to put led DRL on mine and tech2 my normal DRL off)
    Why not wire it to an ignition live? that way you dont need to turn on the side lights?
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    wiring to the ignition live would be best idea, if not wire to sidelights using relay to stop flashing.
    Engine : 2.2 Direct
    Quote Originally Posted by ScotsDragon View Post
    and maby even a relay to switch off when normal lights is on
    gourock
    hi mate i got these from ebay. http://cgi.ebay.co.uk/DRL-8-LED-LIGH...item35a6936868
    think a might change it to the ignition lol but i'm crap with wires so if anyones any good ...........
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Liverpool
    i wanted to do this on my face lift but didnt look right, however looks smart on the preface
    i just dropped a set of led side lights into my fogs........................
    Engine : 2.2 Direct
    i wouldt have guessed that there was room for 15 cm drl... as theres only room for one like 10cm on my prefacelift to fit it on..
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  3. show your led daylights
    By byers in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 17:24
  4. Just Fitted.......
    By KeefyB in forum Petrol Engine related
    Last Post: 22nd January 2010, 21:38
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
