Results 1 to 10 of 11
Thread: Spark Plugs - Cheapo's or not
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Default Spark Plugs - Cheapo's or not
    Just a bit of advice needed really.. I have a 2.2 Direct petrol .. Do I just buy cheapo ngk recommended spark plugs, or are those iridium ones so much better and really worth it? Multi electrode or single electrode? whats better? What do you put in yours? Are all plugs suitable (especially the multi electrode) going to be gap set out of the box? Should I buy specific plugs to satisfy temp range or anything (I really am a DIY mechanic numpty, but Im going to try, lol)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Just normal single electrode NGK's. Used expensive ones years ago and could not find any difference, except to your wallet.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The Direct comes with 4 electrode as standard. I cant call your plugs but stock factory plugs for the none direct 2.2 seam to work out to be the best.
    Jul 2010
    Buckinghamshire
    Thanks a lot, as I thought, iridium wot nots dont represent vaule nor significant gains then.. So I think Im going to probably be getting either NGK BKR5EQUPA or BKR5EQUB .. Should be alright changing 'em, Ive got one of them long socket doobries for spark plugs from way back (about 15 years ago) when I last changed plugs on a car, lol..
    11 Post(s)
    How many miles has it done? They don't need changing until 80,000 miles or 8 yrs.
    Vauxhall "own brand" plugs are fine, and as cheap as chips.
    You shouldn't attempt to regap multi-electrode plugs. All gaps come preset anyway.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by nibblitz View Post
    Replaced the standard VX plug (Bosch & fitted from new) last year at 4 years & 37K miles on our 55 reg Facelift Club with the Z18XE engine....
    ......with NGK BKR5EQUPA(Long Life - 8 years) quad electrode plugs & more expensive than the 'standard life - 4 years ' NGK quad BKR5EQUB plugs, as I work part time for a local motor factors & we stock NGK Plugs
    These are the NGK replacement for the VX (Bosch references in the Vectra C handbook we got with the car - 4 year life or 8 year life plugs covered) The 1.8 VVT plugs are different....
    Didn't expect a noticeable improvement in performance - went for longevity....
    Interestingly, for my nephew's 54 reg Zafira with the Z18XE engine the NGK plug reference was BKR5E. It seems to run fine with these..
    I checked the NGK catalogue @ work & also the NGK web site for cross referencing to be sure before buying them...
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Tony W View Post
    i would not fit ngk plugs into a vauxhall unless they were factory fitted,the heat range on the ngk plug is wrong,the correct heat range is actualy in between bkr5ek and bkr6ek (bkr5e and bkr6e on later cars),i also have seen several engine faliures because of ngk plugs on vauxhalls,in one case the centre electrode fell out causing some engine damage,i used to work for a vauxhall main dealer and from experiences working there i will only fit ngk plugs to my motorbike
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by solorider View Post
    No probs so far....
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I always used to fit the Bosch 4 electrode plugs, the sharknose BMW's, Toyots Celicas etc I had back then seemed to run smoother on them, never had any starting problems either.
    Fitted a set to a Rover 623 GSi I owned briefly and the onwers club went nuts, said the same about Bosch and Rover's as Solorider says about NGK and Vauxhall.
    In the days I was running £200-500 cars I could afford to try it and see, don't fancy blowing up this one, not even the glow plugs lol
    May 2008
    Derbyshire (south)
    Buy the ones from the dealers, they're cheap as anyone elses. £15 i paid for my set.
  1. 3.2v6 best spark plugs to get?
    By PANDY 3.2 V6 in forum Petrol Engine related
    Last Post: 14th February 2012, 02:15
  2. Spark plugs 2.0T?
    By Steven in forum Petrol Engine related
    Last Post: 24th September 2011, 16:43
  3. Spark plugs
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 20:36
  4. spark plugs
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st October 2008, 06:37
  5. Spark plugs for LPG
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 3rd December 2007, 09:17
vectra c z22se spark plug gap
