Results 1 to 3 of 3
Thread: Parking Sensors stopped working
    Jun 2009
    Brighton
    Default Parking Sensors stopped working
    Hello all. My parking sensor system stopped working. I think they are factory fitted. Fuses OK; Haynes manual has not enough detail to diagnose. I took sensors off and tried to measure with meter but not sure what resistances I should find? Any tips on how to check the system out
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    What is the fault code? Try padel method or tech2/vauxcom. Factory paking sensors should have a push button below hazard light switch.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If they are factory fitted you should have a fault light in the clocks. If they are aftermarket and have just stopped altogether worth checking the pos and neg wires
    If there is nothing obvious you'll need to have it plugged in to check for fault codes
  1. Sat Nav Stopped Working
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 19:24
  2. parking sensors not working
    By gsi-robster in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2012, 18:57
  3. Parking Sensors stopped working, Please Help?
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2010, 14:12
  4. parking sensors and power sockets stopped working
    By charliepirate in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2010, 13:37
  5. Parking Sensors stopped working
    Last Post: 30th May 2010, 09:43
vectra c parking sensor fuse
my rear parking sensors have stopped working on my vectra
fuse for sensor reversing vauxhall vectra
vauxhall zafira parking sensors fault
vauxhall zafira parking sensors fuse
