Thread: bit of help please
    Regular Member elite lee's Avatar
    torquay
    Default bit of help please
    driving home tonight from work, i noticed a sort of humming noise coming from the back of my signum. its like a drone sort of noise which increases with speed, at low speed theres no noise but as i increase to around 30- 35 it gets louder.
    just wondering if anyone can give me some ideas as to what it could be
    cheers in advance
    PRESTON
    tyre pressures worth a check or maybe a wheel bearing on the wayout.
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    Could be a number of things mate could be your bearings or another common one is the tyers.
    torquay
    just checked the pressures and they are both spot on
    Regular Member Exclusive BV's Avatar
    West Midlands
    How new are your rear tyres?
    If they have been on for a while they could have developed the uneven wear pattern which can cause noise on these cars.
    There are two things you can do.
    1. jack up the rear and spin the wheels to check for bearing noise/play
    if they seem fine
    2. swap the rears to the front to see if that cures it
    torquay
    is it a big job if its the bearings
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You'll probably find its the tyres, mine have just worn down and they made a droning noise. Now replaced with new tyres and noise has gone
