Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: Dpf removal company
    woking
    Default Dpf removal company
    Right 3 times in 2 weeks my dpf has clogged and f'd up my car I want it off.
    I dnt want a remap as I'm happy with my crd-t box I just want the dpf removal software any good companies with reasonable pricing?
    Sep 2009
    Glasgow
    sure there is a how 2.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    didnt someone remove it knock out the insides then refit it?
    woking
    ^^^that sound like a easier idea if it works^^^
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by lgtuk View Post
    Ask Winnie2457, i'm sure he done it.
    Gazza4
    PRESTON
    this is what winnie posted, hope he dont mind me reposting this, hope it helps.
    New update jut been outside for 3hours now lol and removed the dpf very easy to do really if you have the right tools
    Undo the rear bracket and undo the rear clamp it has one 14mm nut once thus is off then remove the temp sensor on the side of the dpf a 17mm coller and then pull out temp sensor
    Undo the 3 12mm nuts holding the flexi on to te front of the dpf and remove the 2 pressure pipes at the top held on by spring clips then twist and bang with a big hammer it will slide off the rear clamp then take out from under the car
    Any more questions just ask
    And thanks for all the help best no so far I have done
    I then drilled and bashed out the insides to get rid of the honey comb etc once it was completely empty I then refitted in reverse once all back on again I went under the bonnet and crimped over the small pressure sensor pipe then reset the saturation to zero on op com you don't need to do this
    Started up and no lights been fir a drive and wow much power from 1200rpm and gies like stink now a totally different car
    Thus was my problem it was fully blocked but I had no lights at all to show me just lack of power through the rev range at all
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Course I don't mind you reporting I'm glad to help any body follow my how 2 if you live near I will help you do it it's not hard honest just a bit fiddly all depends on how rusted the bolts are mine were not too bad
    Any questions ask me or pm me keep us updated
    woking
    So why are all these remaping companies quoting me 250 - 400 to remove the software if it that easy but if it works it works I just don't live near u winnie
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    By removing the said article what effects would it have on the car.
    It was originally put there for a reason.
    PRESTON
    nothing negative that has been encountered yet, seems to improve more than anything. originally it is there to meet emission controls and taxation reasons to attract company car drivers. yet the same engine in a manual hatch doesn't have one, so i cant see any harmful effects.
  1. Anyone used this company?
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 19:17
  2. sometimes my company really P's me off
    By shaun260589 in forum General Chat
    Last Post: 22nd March 2010, 19:15
  3. bad company on ps3
    By vectrabob in forum Games Room
    Last Post: 9th October 2008, 08:07
  4. Company car help
    By aerodynamic18 in forum General Chat
    Last Post: 2nd June 2008, 12:36
  5. Help - Company Car
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2007, 10:16
