Thread: Cdti 150 spanner light flash when reved and very jumpy cough
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    Angry Cdti 150 spanner light flash when reved and very jumpy cough
    Hi, went out to my car this morning spanner light was on when i started then the car-engine, it started shaking running like it had a cough, tryed reving and just got worse like a cough and the spanner light would just flash, was wondering if anyone has any ideas what it is? btw i havent moved the car just turned the engine off and came back in.
    Cheers Al
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    Sounds very much like 3rd injector wiring issue.. Have a search on the forum for it. good thing is its not too much of an expensive repair
    fareham hampshire
    Wasnt sure if this could be the cambelt as it needs changing mileage is 82k was going to get it changed this weekend, will any of these faults show up on a diagnosic test? im debating wether to try and drive the car tomorrow to the garage but will this do more damage? its 2 miles away.
    Thanks Al
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    doubt its the cambelt... try firing the car up and then wiggle the wiring near injector number 3... if it then runs smoothly then theres your answer
    fareham hampshire
    Will try that in the morning is there anything else it could be while im there, Cheers
    fareham hampshire
    been out this morning and checked the 3rd injector wiring and the unit is loss compared to the others also i noticed it has the new blue unit not yellow as i have read, engine running fine no spanner light, strange! do you think it will be injector unit that needs replacing as it has alot more movement than the others. just going to see if i can get a diagnostic done but not sure if anything will show up but will advise them about the 3rd injector unit after if nothing shows up
    Thanks Al
    fareham hampshire
    Yep just as you said plasma
    took it to the garage had to pay £20 for the test and injector number 3 is showing a fault, covered under warrenty aswell so lucky for me the work is getting done monday for free.
    Thanks Al
  1. cdti 120 jumpy
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 26th December 2012, 21:59
  2. V6 CDTI EML Spanner light
    By mattsbmw in forum Engine & Drivetrain
    Last Post: 15th August 2011, 21:38
  3. cdti 120, spanner light.
    By frasedeb in forum Diesel Engine related
    Last Post: 11th June 2010, 06:50
  4. 1.9 CDTi (150) with spanner light...
    By parsco in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 16:09
  5. 1.9 CDTI (150) Spanner light
    By djr69uk in forum Engine & Drivetrain
    Last Post: 17th September 2008, 15:44
