Thread: Airbag Light on and off
    Jul 2010
    warrington
    Default Airbag Light on and off
    Hello
    2004 Vec DTI
    I have the airbag light come on and off, I have had a quick look under the seats to see if its a loose conenction but I cant see it or feel a loose connection,
    The front seats do get moved quite a bit as me and the missus both drive it!!
    Is there anything else that could be causing this?
    Rich
    Jul 2010
    warrington
    Anyone??
    Full Member Big Sig's Avatar
    If you have checked the seat connections maybe its time to get the fault code read to narrow down which one is causing problems.
    Regular Member Innes's Avatar
    Plymouth
    I had this on my 02 DTi and it was a losse connector under the passenger seat. I know you said you've had a look but my connector into the black box looked in but it wasn't quite in-enough. A good firm push and a click later the light went off.
    If you are sure its in then its code-reader time I'm afraid.
    Jul 2010
    warrington
    Thanks for info
    If the airbag comes on and stays on, there would be a fault, Surely if its on then off, then off for a few days, then on for a few days, its a loose connection!
    I will have a good look under both seats and the black box under there! Then its code reader time!! Fingers crossed its nothing major!!
    Rich
    A loose connection is a fault. A code reader that can read the air bag system will tell you exactly where to start looking.
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Troubleshooting
    Last Post: 16th April 2011, 16:29
