Thread: Exhaust Rattle ???
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default Exhaust Rattle ???
    When changing into second at low levs and giving some gas there is a low rattle from the front of the car. This quickly goes away as the revs rise.
    It seems to be getting slowly worse.
    I think it could be the exhaust but i have not had a chance to check
    Is there anything else it could be???
    1.8 VVTi
    Regular Member crespo's Avatar
    Bournemouth
    Sounds like your flexi pipe to me. If it is dont pay for a new exhaust section get the flexi cut out and replaced for between 50 and 80 quid.
    West Midlands
    Where is this flexi pipe?
    I am guesssing between the manifold and cat
    WGAF#5
    stick your head under the car - could also be the outer skin on the rear box degrading - or even a underbody heatshield coming away
    West Midlands
    cheers for the ideas, I'll be checking all these tonight when I get in.
    i'm Pretty sure it's coming front the front but you never know
    West Midlands
    Crespo, based on your recommendation I just found this thread.
    http://www.vectra-c.com/forum/showthread.php?t=53152
    What do you reckon?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The flexi should last for ages. What likely to go first is the wire mesh that covers the flexi. Mine rusted through at both ends and would move up and down the pipe while driving. All you have to do is cut it off, its only there as a garnish.
    stockport
    Had a similar problem with my car.It used to vibrate/rattle as I pulled away then dissapear.
    Took it into NTS and they found it was a metal securing bracket on the down pipe section that had broken.They welded it up,now,no problems.
    West Midlands
    Quote Originally Posted by felixx View Post
    Cheers for the info, i'll check that too
    West Midlands
    Ok, I was under the car for a good 20 mins poking around. The flexi pipe was not really that noisy when i shook and poked it so i dont know whether to put a jubilee clip on or not.
    I rattled and shook everything I could see including the heat shields and there were no obvious signs of exhaust deterioration anywhere, the whole system including the back box seems to be in pretty good nick.
    As I cannot yet find what is making the noise, i will monitor it for the time being but if it gets much worse, i will take it into get looked at.
  1. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  2. rattle
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 20:08
  3. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  4. Replies: 7
    Last Post: 22nd August 2007, 21:16
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
vecfra c exhaust rattle
vauxhall vectra exhaust rattle
vauxhall insignia vibration from exhaust flexi joint
vectra c cataylitic converter rattle
vectra c cdti has a new flexi pipe and now i get a vibration
how do i stop the flexi hose on bottom of downpipe on vectra c rattling
