Thread: tryes ?
    redcar
    Default tryes ?
    hi all
    just need the above answered please,am due to put some tyres on but am bit confused , have got 215 * 50* 17 on atm but would i be right in thinking that if i put 235 * 45 * 17 on the car will handle a bit better.
    thanks clembo
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    225 45 r17 is the alternative size recommended by VX, it's in the hand book. 235's would be pushing it
    Quote Originally Posted by clembo38 View Post
    Depends on the make of tyre.
    Also in the wet a wider tyre could actually make the handling worse as you've a larger footprint on the road which could aquaplain far more than a narrow tyre.
    But as said by John, the alternate size for 215/50/17 is 225/45/17.
    redcar
    hi thanks for the reply have been Lizzy of late,have just done the tyre calculator size if i go for 225/45/17 the car will be running 1.9 mph faster than the slandered tyres, but put in 235/45/17 its just 1/2 mph faster so my thinking its better for speedo accuracy,or is that not the case.
    thanks clembo
    Presumably you actually mean a % rather than mph variance
    I posted about this before, changing from 215/50R17 to 225/45R17
    My car now runs faster than the displayed speed, but it is still within the Vehicle Construction Act tolerance of 10%
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    235's are only recommended by VX for 19" wheels and then only with a 35% side profile - i.e. 235/35/19
    225's with a 45% side profile are recommended for 17" and 18" wheels - i.e 225/45/18 or 225/45/17
    215's with a 50% side profile are recommended for 17" wheels - i.e 215/50/17
    Full Member Big Sig's Avatar
    thanks clembo
    That's all ok assumingits correct now, which it's not.
    redcar
    thanks all meant percentage don't know why i put mph. i now under stand.
    thanks clembo
    leeds
    I can chip in here as I have just replaced the original fit Goodyear Eagle NCT5 which were 215/50/17 with Michelin Primacy HP 225/45/17.
    Even though they are wider, the lower profile still makes the sidewall smaller, and overall it does make the wheels look a bit smaller but I will get used to that as it's only a bit.
    The speedo can be corrected if you have access to a Vaux-Com programmer. You can program in a different tyre size and the speedo reading will be correct again. Doesn't make a lot of difference though.
    The handling is transformed by the way. These Michelins are great, there is less roll in corners and a lot more grip than the Goodyears. Also I am still getting the comfort I like from my 'old man' elite spec. Nice and quiet too.
  1. the cost of inflating your tryes
    By hoochydady in forum The 'Off Topic' room
    Last Post: 22nd June 2011, 12:07
  2. HELP: Correct tryes for my Signum
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2011, 20:52
  3. Should I get 4 new tryes?
    By thedon1066 in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2009, 19:08
