Thread: Fault Code Help - Spanner On - Cars fine
    Huddersfield
    Default Fault Code Help - Spanner On - Cars fine
    Well chaps after just thinking that my Vectra was great the dreaded spanner came on!
    It came on just after filling up diesel after a 90 mile journey and up to that point and afterwards has run fine (just with a light). The light wont go off after clearing the faults. I've managed to produce the below report and posted it below:
    DIAGNOSTIC REPORT:
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0014
    VIN: W0L0ZCF3571097448
    Part Number:13204147
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 070330
    No fault codes stored.
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x131D
    System name: Z19DTH
    Hardware number:81012868
    Part Number:55201791
    Software version number: HJOAS150_S
    System description: BOSCH0100
    Type approval number: B07008
    Alpha code: DM
    Number of stored fault codes: 1
    P1700 - <Unknown DTC>
    (00) - Present
    Source Address: ATM/MTA
    Source Address: 0x000007E1
    Identifier: 0x0606
    VIN: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
    Hardware number:55560155
    Part Number:55559861
    Software version number: 9939300833
    System name: AWF8HHM4 Z19DTH
    System description: AISIN0200
    Alpha code: PS
    Number of stored fault codes: 2
    P0602 - <Unknown DTC>
    (00) - Present
    U2101 - <Unknown DTC>
    (00) - Present
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x6003
    Hardware number:0
    Part Number:12773671
    Software version number: 00C2E92D
    System name: ABS 430 NG
    Alpha code: BS
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    Hardware number:24444336
    Part Number:0
    Software version number: V21_
    System name: EHPS GEN3 TRW
    System description: TRW 0300
    Alpha code:
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x1503
    Part Number:13193058
    Software version number: 3.40 10/05
    System description: VDO 0400
    Alpha code: RW
    Manufacturing date: 070419
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (7F) - Not present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0102
    Part Number:13186947
    Software version number: 0C0D4B11
    Alpha code: KN
    U2139 - Invalid Data from CIM (Steering Column Module)
    (00) - Not present
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0209
    Part Number:13193590
    Software version number: D02D11 49041605
    System description: TEMIC04
    Alpha code: NF
    Manufacturing date: 000700030104
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0105
    Part Number:13205774
    Software version number: 00000FA1
    System name: REC
    System description: LEAR 0400
    Alpha code: FP
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0105
    Part Number:13240243
    System name: UEC
    Alpha code: JE
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0106
    Part Number:13193368
    Software version number: OP1D 193000
    System description: SIEM 0401
    Alpha code: JQ
    Manufacturing date: 714070
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0105
    Part Number:13193369
    Software version number: OP1D 192000
    Alpha code: JR
    Manufacturing date: 804070
    Source Address: SLM
    Source Address: 0x0000025C
    Identifier: 0x0103
    Hardware number:13130892
    Part Number:13130910
    Software version number: 18282002
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1301
    Hardware number:13128263
    Part Number:24461297
    Software version number: CE59-/00050
    System name: CID/GID Epsilon
    Source Address: UHP
    Source Address: 0x00000247
    Identifier: 0x0102
    Hardware number:13187911
    Part Number:13187911
    Software version number: 1.94-/UHP4-
    System name: UHP 4
    Alpha code: ZJ
    Manufacturing date: 20070402
    Quite a bag of mixed codes! In essence they are as follows:
    P1700
    P0602
    U2101
    U2105
    U2139
    I've done loads of googling and searching and think the culprit is P0602 ans that ECU has lost the VIN number setting. I cant access the section to re-enter it without the car pass so will need to order one from VX. Has anyone got any thoughts on this? I think the other U codes are due to possible compatible issues with the software. P1700 is a bit of a mystery as well!
    PRESTON
    P0602 vehicle identification number is not programmed hardware and software B-005
    P0602 injector volume adjustment is not programmed hardware and software B-015
    P0602 tires extent not programmed hardware and software B-003
    P0602 Security code is not programmed hardware and software B-003
    P0602 Control Unit C-002 program
    P0602 control device programming hardware and software B-003
    P0602 ECUs programming errors (lack of out-of-code programming or index)
    P0602 variant configuration is not programmed hardware and software B-004
    U2101 CAN bus (High Speed) maximum configuration list is not programmed hardware and software B-003
    U2101 CAN bus (Low Speed) maximum configuration list is not programmed hardware and software B-003
    U2101 CAN bus (Mid Speed) maximum configuration list is not programmed hardware and software B-003
    U2101 CAN bus maximum configuration list is not programmed hardware and software B-003
    U2105 CAN bus, no communication with the engine control unit Fahrzeugbezogene Prüfanleitung B-019
    U2105 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
    U2139 CAN bus no communication with CIM (Steering Column module) C-003
    cant find p1700 but got the others, hope it helps
    Huddersfield
    Thanks Barney. I've got most of that already . I just wish I knew which one was making the light stay on though
    My House
    Hi,
    P1700 is a rare code and has a few values but the common value is SVS or service vehicle soon and can be for a number of reasons.
    This does not mean to say a service is req, it is ususally a reaction to a lack of coms on the high speed CAN line which can be from the transmission module(auto)
    or from an incorrectly configured high speed CAN
    I had the same issue just today on a vec c elite z19 dth auto where i had to re program the high speed CAN as it did not recognise the other modules on the network.
    Neil
    Huddersfield
    Neil that's really useful to know. The other fault code P0602 may be linked then as I believe this is linked to the auto box as well. I think I've come to the end of my knowledge though after resetting things and clearing things. I think from above read outs that the module for the auto transmission has lost it's memory (no Vin number shown) and needs reprogramming. The software I've got won't allow me to enter VIN in this module (typical eh?!). Main dealer me thinks!
    My House
    Hi,
    It does sound that way,if you need anymore assitance buddy then just shout.
    Huddersfield
    Thanks mate. You've helped to put the pieces of the jigsaw together!
    My House
    Hi Paul,just checked through the reworks for you as i remember in the back of mind a rework for this concern. the number is 08-fr-55 and is a software update.
    it has exactly the same dtc codes and is due to the software level wiping out the vin for no reason.
    take it to your vauxhall dealer and get them to pull this and the feb 09 rework for it.
    Regards,Neil
    Huddersfield
    Neil. Eternally grateful. Thank you. I've just arranged to visit tramman for a Tech2 session and I'll give him the info. If I knew where you were I'd buy you a beer!
    Huddersfield
    Well I'm happy to report that after an hour with Steve (tramman) the software has been updated and everything good again. A big thanks to Neil Dti and Tammany for your help.
  1. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
  2. 1.9 CDTi Yellow Spanner But No Fault Code!
    By Andyg in forum Engine & Drivetrain
    Last Post: 16th May 2010, 22:05
  3. Spanner light; error code 'Preheat delay fault'
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 24th April 2009, 16:33
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
  5. Spanner light coming on P0115 fault code help please...
    By merikiito in forum Engine & Drivetrain
    Last Post: 9th August 2008, 13:07
OPEL U2101-C
Vauxhall U2101-C
u2101 fault code vectra
opel vectra c 2005 u2130 canal bus no communication
u2101 fault code zafia b
vauxhall vectra 1.9 cdti u2130-c
u2101 vectra
u2101 vauxhall
u2101-00 opel
Vectra c 1.9cdti 150 z19dth fault code U2139
