Thread: Deep droning noise under moderate/heavy braking...
    Bridgend, S Wales
    Default Deep droning noise under moderate/heavy braking...
    Haven't been here for a while as the Vec has been behaving since the DMF incident
    However, i noticed yesterday whilst having to brake quite sharply that there is a droning noise as i come to a stop. It only seems to happen if you come to an abrupt stop, whereas if you come to a gradual stop it doesn't??
    Also to my alarm the insides of the front tryes have worn quite badly, the tyres are only around 7 months old and the tracking seems fine, (no wobble or shaking under any speed).
    Cause i know it's there it's bugging me now, and my g/f has also mentioned it.
    Any takers??
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Droning under heavy braking could be down to warped discs. How do you know the tracking is ok? Have you had it checked?
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sounds like it may be metal to metal, but maybe just from the rears as you say its when you brake hard. You had the wheels off to check the brake pads?
    Bridgend, S Wales
    Metal to metal, as in pads worn and creating vinyl record with the disc lol?
    Brakes were checked and mechanic says they'll need doing in a few months as they still have plenty on them. Having been out to check the car tonight i've noticed the front passenger tyre pressure as the wheel is pinched ever so slightly as if it needs a bit of air. It's only started recently and i'm thinking i would have noticed a gradual lead up to this??
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    I get this under heavy braking on mine, so I'd be interested to know what it is too. From inside the car it sounds like it's the front o/s wheel, but then acoustics can be funny and it could be from any of them I guess. I've had a quick look at the pads and there seems to be plenty left. I can't afford new discs/pads this month, so hopefully it'll wait a while.
    I had a set of tyres on my old Volvo where the fronts wore through to the banding on the insides before I noticed. I'm 99.9% sure it was caused by driving at 'some speed' over the speed 'cushions'/'pillows' in the long straight road leading up to where I live. I always try to keep to the limit going over them now and often take a detour to avoid them completely. Do you regularly travel over any?
    Regular Member kamar's Avatar
    bradford
    could also be wheel bearings... or break servo
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    When i had my Nissan it was the topstut bearing that was bust.. when it did that noise.
  1. Wandering during heavy braking ?
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2012, 12:00
  2. Strange noise after heavy braking
    By oilslick in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 12:05
  3. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  4. droning noise when reversing
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2009, 08:52
  5. Full Load, Deep Grind sound when braking?
    By kktdragon in forum Suspension, Wheels & Brakes
    Last Post: 10th January 2009, 14:22
vectra c droning noise
vauxhall insignia droning noise
insignia noise when braking
vauxhall insignia load droning noise under heavy braking
droning noise vauxhall insignia droning noise insignia noise when braking vauxhall insignia load droning noise under heavy braking
vauxhall insignia noise from brakes
vectra c 2007 brake rumbling
brake warble insignia sound
