Thread: Bulb Failure Notification
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Bulb Failure Notification
    I have an issue with the electrics when my caravan is attached.
    When first starting out I can drive for 2-3 miles before the left brake light shows up that there is a bulb out when I have the electrics for my caravan connected, the brake lights on the caravan will not work but the brake lights on the car work fine.
    If I stop, switch off the ignition then re-start they work fine for a short while, then the warning comes back on.
    The lights on the car work fine when the caravan is not connected.
    I would like to know if I continue to use the Van electrics with the bulb notification failure as mentioned earlier in the thread will this do any harm the the car electrics/ecu?
    or is the notification I get on the dash protecting the cars electrics?
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Have you tried to change that bulb?
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    sounds like you got a dickie connection in the caravan or the suzzie going from the car to caravan, try and find someone with a trailer or caravan to borrow and try that. HTH
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like there is a dodgy connection in the carvan some place mate. Check the red wire in the caravan plug and at the lights (brake light wire)
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    I have been told it needs a by-pass relay fitted.
    Any ideas on that?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    What wiring was fitted? If you are showing a bulb check on the trailer I would assume it's the genuine VX electrics.
    Have you tried doing the "hard reset" of the towing electrics thats in the How2 section?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Had a by-pass relay fitted, All working fine now
  1. Bulb Failure Detection
    By Dhrideruk in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 17:19
  2. Bulb Failure notification
    By brentmeister in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2011, 19:21
  3. Bulb failure.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 10:47
  4. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
  5. bulb failure
    By jbr in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 17:11
vectra c resetting bulb failure light
