Thread: Power loss advice please
    May 2006
    Nottingham
    Default Power loss advice please
    Hi
    I have a 57 Signum 1.9 150 Cdti with 52k on the clock. I had the EML light on a couple of months back and they swapped the EGR under warranty and the problem went away. However for the last week the EML light has been on a few times, same symptoms again. It's been into vaux and they have reset the eml but say there was no fault code. I also have a Gendan GCR25 code reader and each time it faults no error codes are generated :-(
    Any ideas?
    Andy
    preston
    if your egr is new then it's unlikely to be that - but it might be worth taking it off to see how it is
    other than that clean your boost sensor with carb cleaner and a soft toothbrush
    while your there
    check all hoses in particular boost hoses, intercooler hoses to make sure they are not split anywhere
    that should rule out some obvious bits
    PS
    When was it last serviced ? can you describe if its losing power at bottom end or through the rev range generally?
    May 2006
    Nottingham
    Had the AA out to it this morning, there fault code reader sees no codes either but shows the EGR self check system as incomplete so he rekons it's a faulty new EGR.
    Booked into the garage tomorrow.
    Loss of power throughout the range, basically no turbo I think.
    Andy
    May 2006
    Nottingham
    Turns out it was the DPF, which suprises me as pretty much all my driving is motorway or fast A roads. They did a tech 2 regen and say the % seem okay, whatever that means. We shall see. They have quoted me 800 for a new one, local garage have quoted just over 400.
    Andy
    preston
    then again
    you could consider not having DPF altogether
    search the various posts on site to see what others have done ie knocking DPF out or just replacing with straght pipe
    £800 seems a lot of money to spend
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2.0T loss of power!!!!!
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 17:23
  3. Cdti 150 power loss advice
    By paulcdti150 in forum Engine & Drivetrain
    Last Post: 12th March 2011, 14:06
  4. Loss of power
    By Silentknight in forum Engine & Drivetrain
    Last Post: 6th October 2009, 15:51
  5. power loss
    By justyb in forum Diesel Engine related
    Last Post: 23rd January 2008, 02:22
