Results 1 to 10 of 24
Thread: Cambelt kit & water pump change
    Jul 2010
    Oldham, Lancs
    Angry Cambelt kit & water pump change
    Ok, so I changed my cambelt will tensioner and guides as well as the water pump. Now its running again, the engine is very noisy (tappet sort of sound) and struggles to start first time.
    Anyone any ideas what it could be?? Or could give me pics of the vx timing marks to line back up and start again.
    2006 Vectra C Z19DT engine.
    Jul 2010
    Oldham, Lancs
    I just had a look in TIS. I dont think we have tensioned the belt fully, would this cause the engine to rattle??
    Anyone know??
    PRESTON
    Jul 2010
    Oldham, Lancs
    Cheers for that. Seems to be some confusion about the crank positioning on TDC when putting on the timing belt. These images are from TIS 2000;
    Crankshaft timing at 8 o'clock ish.
    Attachment 34181
    Camshaft timed as marks on engine and pulley.
    Attachment 34182
    Hope this helps someone. Ill be re-doing my belt tomorrow. It turned over pretty freely, so it should just be a time up and belt replace. I hope!!!
    PRESTON
    i would go with tis everytime. it strikes me that the crank marks on both the 120 and 150 are in the same place. If you look at both tis and the sealy tool, it would appear that the mark on the crank should be inline with the oil pump bolt NOT the notch in the cover at 5 o,clock.
    To me, the dowl on the crank pulley lines up with the notch in the cover and the white mark on the crank pulley is in line with the oil pump bolt at 8 o,clock.
    PRESTON
    i did also hear that an incorrectly tensioned cam belt can cause a rattle/tappet sound, hope the sealy info on tensioning helps you get it sorted, keep us posted
    Jul 2010
    Oldham, Lancs
    Thanks for that. Ill try sorting it today - just hope no damage done!
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Hi, I am due a cambelt change too on my 120. How much did the cambelt kit and waterpump cost you? Thanks
    Jul 2010
    Oldham, Lancs
    Managed to sort my motor. It was out by 1 tooth on the cam! Bleeding thing!! Sounds fine now. I bought a cambelt kit, water pump & accessory belt (fan belt). It was £107 inc vat. That was from a place in Radcliffe near Bury.
    PRESTON
    glad you sorted it pete, do the timing marks line up as we suspected? i checked on a gates timing belt kit today, and the marks are excatly as we discussed.
  1. Y30DT Cambelt / Water pump change
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 23:13
  2. Cambelt & Water Pump
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 00:48
  3. 3.0 v6 cambelt/water pump
    By bigsteve3.0v6 in forum Y & Z30DT Specific
    Last Post: 11th September 2011, 23:44
  4. Cambelt and water pump change
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 14:39
