Thread: cdti150 air whoosh noise!!
    Carnoustie
    Default cdti150 air whoosh noise!!
    noticed this air whoosh noise when giving it a rev or driving whilst hard excelerating, either air blowing in or out somewhere? seems to be near the air filter box, had this with our other vectra but much louder it was under warranty and was a turbo pipe, had a poke around but not seen any split hoses anywhere, new air filter also fitted, anyone any ideas?
    thanks Ronnie
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The split might be really small, not enough to cause problems but enough to hear the air escaping.
    Gazza4
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Chances are it's the u bend intercooler pipe which you can see unless you take your splash cover off an crawl underneath all it needs is a tiny split to make any noise as 22psi is quite a but of pressure especially with high flow
    Carnoustie
    Quote Originally Posted by winnie2457 View Post
    cheers guys, the cover was off earlier today too when the oil was changed and it was on a ramp, doing the front pads in the morning so will have a looky, pain in the neck as you need another pair of hands, well feet to give it a rev, but I think it has lost a little Ooomphh since the noise
  1. 1.9 CDTI150 thermostat
    By Hideous in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 21:19
  2. whoosh/possible rattle when flooring
    By Fash in forum Engine & Drivetrain
    Last Post: 20th April 2010, 21:43
  3. CDTi150 kit on a CDTi 120?
    By EwenVC in forum Diesel Engine related
    Last Post: 14th February 2009, 00:44
  4. Whoosh and thick grey smoke!!!
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 00:38
  5. I'm Whoosh and I am a Signum owner
    By Whoosh in forum Introduce yourself.
    Last Post: 29th July 2007, 14:26
