Thread: i need part number for egr blanking plate 2.2 direct Z22yh
    london
    Default i need part number for egr blanking plate 2.2 direct Z22yh
    hello i see folks on here paid £5 for blacking plate.
    dealer said it cost £35
    can some one tell me the part number for blanking plate
    03 signum 2.2 direct z22dh engine
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    PM Sambor mate as he bought one. Although you can do it for free by fitting a blanking gasket made from a coke can to where the EGR pipe from the manifold meets the head. The Blanking plate for the EGR on the Direct is really for if you are taking the whole system out and that involves dealer programming @ about £50. If you having problems with your EGR and are getting warning lights then blanking alone wont fix anything as the EGR still has to be able to open and close freely.
    london
    Hi I bought part number 24575592
    Which is a plate that covers the hole on the manifold. But the pipe won't fit on it. Thanks for the coke can info as I have some alloy sheet that's thicker than coke can. Bought form rc hobby store . That should work
    london
    The egr is working fine but I want to blank it as it puts tone of muck in the manifold . And people say it makes the engine runs better cooler and kill a few flat spots
    Vehicle : SRi
    Mileage : 137000
    The engine will run hotter if you blank the EGR because the burn will be better, but you may find you Drop a couple of MPG in the winter months. I didn't know there was another blanking plate available, the only one I knew about was the main one that goes on the side of the block when you actually remove the EGR. Don't forget to leave the EGR plugged in.
  1. Z22YH EGR Blanking
    By justathome in forum Engine & Drivetrain
    Last Post: 20th June 2015, 18:38
  2. What can u do to a 2.2 direct Z22YH
    By Kcriyback in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2012, 00:40
  3. t/c switch Part Number for a 54 Plate
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2008, 16:51
z22yh egr blanking plate
egr blanking plate vectra c 2.2 direct
