Thread: z18xe limp mode (lack of power jugeling) !!!withop-com readings!!! please help
    norway
    Vehicle : vectra c
    Engine : 1.9 cdti (120)
    Default z18xe limp mode (lack of power jugeling) !!!withop-com readings!!! please help
    hi i was wondering if anyone cud stear me in the right path
    the car is a opel vectra 1.8 2005
    for the last 2-3 weeks it has been juggeling and lacking power almost feels like a stal some times. mostly in swings, round abouts and up hill.
    things that iv have tryed:
    Oil change , air filter change , cleaned the mas meter , changed sparkpluggs and cleaned lamda 1 (just over the cat)
    vith litle help even tryede a full tank of vpower (it has som cleaning sulution in it)
    i dont have a lot of doe left so im hoping i dont have to fork out a lot of doe for stuff i dont need. here are the op-com readings
    OP-COM 090820b - PC based diagnostic tool
    Date and time>,27/07/2010. 12:13
    Workshop information:
    Please add your workshop
    name in the settings window
    Selected model>,2005,Vectra-C / Signum,Engine,Z 18 XE
    Control Unit:
    Identifier: 0x0206
    VIN: W0L0ZCF3551020091
    Hardware number:2001000
    Motor type: Z18XE
    Part Number:55557540
    Software version number: 6577915106
    Programming Date: FFFFFFFF
    Hardware key number: ˙˙˙˙˙˙˙˙˙˙
    System description: SIEM 0100
    Type approval number: S05009
    Alpha code:
    Hardware manufacturer system name: SIMTEC71.6
    Code Index and version: O455001C
    Measuring blocks information:
    B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
    B1S1 O2 Sensor (Bank 1 Sensor 1),39 mV
    B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Lean
    B1 O2 Sensor Loop (Bank 1),Open
    B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
    B1S2 O2 Sensor (Bank 1 Sensor 2),98 mV
    B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Lean
    B1 Short Term Fuel Trim (Bank 1),0 %
    Catalyst Protection Enrichment (Bank 1),Inactive
    Intake Manifold Valve 1,Inactive
    Full Load Enrichment,Inactive
    Desired Engine Idle Speed,688 RPM
    Idle Speed Modified,NO
    Idle Speed Offset,Inactive
    Vehicle Speed,0 km/h
    IAGNOSTIC REPORT:
    OP-COM 090820b
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0015
    Part Number:13162134
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 040827
    No fault codes stored.
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0206
    System name: Z18XE
    Alpha code:
    Number of stored fault codes: 1
    P0170 - Fuel Trim System Lean
    (12) - Not present
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0301
    Hardware number:12801327
    Part Number:13136694
    Software version number: 00C3552E
    System name: ESP EBC430
    System description: TRW 0300
    Alpha code: EZ
    Number of stored fault codes: 2
    U2142 - CAN-Bus No Communication with YRS (Yaw Rate Sensor)
    (00) - Present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Present
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    Hardware number:24444336
    Part Number:0
    Software version number: V20_
    System name: EHPS GEN3 TRW
    Alpha code:
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x0102
    Part Number:13186692
    Software version number: 8.39 16/03
    System description: VDO 0400
    Alpha code: EC
    Manufacturing date: 040916
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0101
    Part Number:13170589
    Software version number: 0C0C3303
    System description: 0x41533035383953303431373134384420
    Alpha code: DX
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0109
    Part Number:13199490
    Software version number: C13C96 13041704
    System description: TEMIC04
    System description: 0x20202020202020303030373539333839
    Alpha code: KH
    Manufacturing date: 000400090105
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0104
    Part Number:13189924
    Software version number: 00000BBD
    System name: REC
    System description: LEAR 0400
    Alpha code: EU
    B3883 - Rear Licence Plate Lights Circuit Open
    (04) - Present
    B3596 - Invalid Trouble Code Please Ignore!
    (00) - Present
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0104
    Part Number:13187504
    Software version number: 00000BBC
    System name: UEC
    Alpha code: EH
    (00) - Present
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0301
    Part Number:13170178
    Software version number: OP1D 190000
    System description: SIEM 0401
    Alpha code: EL
    Manufacturing date: 038040
    B2966 - Driver Doorknob Circuit Open or High Voltage
    (05) - Present
    B1640 - Driver Mirror Heater Circuit Malfunction
    (00) - Present
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0301
    Part Number:13170177
    Alpha code: EN
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1201
    Hardware number:13178572
    Part Number:13178765
    Software version number: GE55-/00050
    System name: CID/GID Epsilon
    System description: SIEM 0400
    Alpha code: SD
    Manufacturing date: 20040906
    Source Address: ECC
    Source Address: 0x00000248
    Identifier: 0x0201
    Hardware number:13131021
    Part Number:13138198
    Software version number: C502 V40D201
    System name: ECC 0620
    System description: 0x33383831383420000400090104303132393100
    Alpha code:
    Source Address: EHU
    Source Address: 0x00000241
    Identifier: 0x0208
    Hardware number:13188435
    Part Number:93184763
    Software version number: 08.00/-----
    System name: CD 30 MP3
    System description: BOSCH0400
    Alpha code: LR
    Manufacturing date: 20050825
    Source Address: DIS
    Identifier: 0x1201
    Alpha code: SD
    Coil pack?
    Jul 2010
    Londonderry Northern Ireland
    P0170 is usually a faulty lambda sensor
    norway
    Vehicle : vectra c
    whitch one... the one in the fron (by the manifoil/cat) or that one under the engin?
    norway
    Vehicle : vectra c
    anything els? iv seen that its pausible to buy a universial lamda anyone tryed that?
    is it more comon for the one in the front or back to go (lamda1 or 2)
    May 2008
    Tyneside
    Just had a similar problem with mine. Turned out to be a collapsed/blocked catalytic converter. Have you checked the tailpipe to see if you get a good flow, also noted the cat getting very hot with engine running 5 deg hotter.
    norway
    Vehicle : vectra c
    i hadent thaught of that... cud bee? ill try to cheak to morow..
    im going to our lokal opel/vauxhal scrapers ,he only deals in those .
    and wee will ty to changs difrent parts a se what hapends with th op-com on
    norway
    Vehicle : vectra c
    I went to the opel/vauxhall scraper yesterday were we tryed a difrent things while haveing there pro laptopp conected
    replased the Mas and , and the coil pack
    we cheaked the cat and tokk out the lamda . he ment it must be blocked somewere probobly in the fule system.
    the fulepump is only 6 months old , so i putt a new fule filter and plenty of injection clean and lube. tryed to mesure the fule pressior butt my fule metter just went over mesuring force... so that sude be fine.
    i noticeed ween i was going upphill it started nugging and strugeling ween i putt the pedal to the flor it stoped nugging and started to stedaly clime
    and ideas
    jilava
    Did they try to fix these DTCs?
    (00) - Present
    (00) - Present
    norway
    Vehicle : vectra c
    dont know... i think that they are there becaus of the car wasent runing/switched on
  1. Limp mode - no power :(
    By Big Knox in forum Engine & Drivetrain
    Last Post: 1st March 2016, 12:26
  2. Power loss like limp mode no code/light
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 19th March 2013, 10:27
  3. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  4. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
z18xe lack of power getting hot
collapsed catalytic converter z18xe
z18xe limp mode
