Thread: Fuses/Aircon
    Regular Member paul4400's Avatar
    Lowestoft
    Smile Fuses/Aircon
    Aircon not working on our car, when you push the button there are no noises ie relay clicks or rev changes.
    Have looked through the fuses and all fitted ones look ok, there are some however that have contacts but no fuse in them, the one i am not sure about is in the passenger side fuse box and its No 18 which in my hand book says Ignition terminal 15 Air conditioning, does this need a fuse???
    Thank
    When did it last work? It may need regassing. If the system has low pressure the car won't let the compressor kick in and burn out.
    Lowestoft
    Default aircon
    Dont know when it last worked as only got the car on saturday
    Also there is a fuse missing in 21 on the same fuse board and the handbook says its Telematics???? whats that
    No idea!
    However if the A/C isn't used often enough the seal dries out and the gas escapes. My moneys on it needing a regas
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    if the AC button lights up then it's more than likely just needing a regas. BTW the telematics is part of the phone system on the NCDC 2015, Bigmac has it fitted to his (it goes under the heater controls)
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Fuses
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 00:50
  3. Help with Fuses!
    By SRIstu in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2008, 22:49
  4. Fuses
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 17:06
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
vectra c forum air con
aircon fuse insignia
vectra c air con fuse location 2007
insignia air con compressor location
insignia aircon relay
2009 vauxhall insignia air con fuse location
