Thread: Fan not working except on full
    Chorley
    Default Fan not working except on full
    Hi, new to the forum but hoping someone could help. My fan has stopped working on 1,2,and 3 but still does on number 4. It was making a noise a few weeks ago so I sprayed a little oil on the fan and the noise stopped. Heater works OK.
    Any ideas on how to fix?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You need to replace the resistor in the passenger side foot well, about 25 quid from the stealers
    Regular Member pugs,signum's Avatar
    swansea
    could be the brushes
    If the brushes are well worn they wont make the motor spin until there's so much power going into the fan that it will then work, hense it's not working till its on full power!
    I bet the pollen filter drain is blocked too
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by pugs,signum View Post
    Its a possibility mate, but odds on its the resistor pack as John said, its a very common problem.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Only just occurred to me the other day that the same thing has happened to mine.... Always drive around with the air on at least setting 1 but can't feel it until 5-6
    Thanks guys, i'll have a look into it!
    Regular Member stuart813's Avatar
    gosport
    Had the same problem with mine went to Maplins to get a new thermo resister. Alot cheaper than a stealer or flea bay
    Regular Member howardc03's Avatar
    lincolnshire
    easy fix this pollen filter drain is blocked which means water goes where it should not do straight into the resistor pack which is located behind glove box right against bulk head quite expensive from vauxhall dealers bout £30 from breakers or 69p for a replacement thermal fuse from maplins and ya solder this in to resistor pack yourself
  1. Wipers not working on Full speed
    By jbrines in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 15:27
  2. Replies: 3
    Last Post: 15th November 2010, 13:14
  3. So thats what a 1.9 CDTi working on song in full harmony feels like!
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2010, 19:06
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  5. Interiror fan only working on full?
    By Spesh in forum Bodywork & Interior
    Last Post: 9th March 2009, 18:50
