Thread: Now that's what you call a hole! (turbo pipe)
    KENT
    Default Now that's what you call a hole! (turbo pipe)
    After several attemps of checking for leaks in the turbo pipes (due to spanner ligght and loss of power) I decided to check the whole lot of pipes and found the lower pipe (under air box) to have this massive hole in it.!
    It was already covered in duck tape I guess from previous owner! I have now patched it up and hope it will work.
    Does anyone know what this pipe is called???? It was a Ba ****** d to get out!
    I hope this will stop the black smoke and loss of power.
    PRESTON
    intercooler feed hose maybe, is it a 2.0 dti and runs from the turbo down to the intercooler?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep thats the intercooler pipe all right, definatly the cause of your problems
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    **** thats one big hole, how the hell did it get that size
    KENT
    I have no idea - just found it. was already wrapped in duck tape
    Any ideas how much for mew intercooler pipe?
    Oct 2009
    Sandwell
    Quote Originally Posted by 123ashleyp View Post
    how about a few layers of heat shrink and 2 cable ties ?. Ive used heat shrink on 1 of my pipes and it does the job just right
    KENT
    thats good idea. i used a piece of rubber glued over hole then wrapped in duck tape with cable tie
    Oct 2009
    Sandwell
    i tried to use tape on mine to start with but it melted the glue with the heat but heat shrink does do the job
    Jul 2010
    Birmingham
    Hi i got a pipe like that one, send me a message if you want to buy it
  1. Turbo Pipe
    By Elahi_786 in forum Diesel Engine related
    Last Post: 6th February 2011, 20:12
  2. loud turbo hissing, hole in intercooler pipe maybe???
    By jamie_hepp in forum Engine & Drivetrain
    Last Post: 8th October 2010, 20:25
  3. any one got a turbo pipe lying about
    By hmc_vectra in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 22:22
  4. Turbo pipe!!
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2009, 22:50
