Thread: oil in intercooler
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Default oil in intercooler
    we think we may have worked out where the oil in the turbo is coming from .
    the intercooler !!!!!!!!
    any ideas people how and why?
    and if any one has tips to empty the intercooler of the oil and prevent it happening again
    Regular Member LADmachining's Avatar
    Hampshire
    It's usually the other way round - the oil in the intercooler comes from the turbo!
    To clean the intercooler, its a case of removing it from the vehicle, then flushing through with degreaser, then allowing to dry fully before refitting.
    West
    As above... the turbo is passing oil into the intercooler
    Regular Member sla002's Avatar
    hayes, middlesex
    think i have the same issue. is this normal for the turbo to leak a little oil or does it mean the turbo has had it.
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It is likely coming from the oil feed pipe to the turbo and past the seals and blowing into the intercooler
    PRESTON
    yes it is normal for oil mist to get into the intercooler from the turbo, also remember that the engine breather system is piped in, between the turbo and the intercooler, so you will also get oil mist from there as well.
    CORNWALL
    I'll get the photos off my phone after Hollyoaks and show you what we found in the turbo and the pipe from that to the air box.
  1. intercooler?
    By justin32 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 17:09
  2. Intercooler
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 12:36
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Intercooler
    By user999998 in forum Engine & Drivetrain
    Last Post: 16th May 2008, 11:02
vectra c 1.9 oil in intercooler
