Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Something ain't right !
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Question Something ain't right !
    Coming back from a fishing trip last yesterday evening, i had to slow rather quickly due to a crow stood in the road eating a road kill ! (not damaging my car !).
    The car stopped very quickly with the 314mm brakes but it squirmed all over the place !!!
    It was like i had no control of the direction the car was pointing.
    I had a new steering rack under warrenty last year so i can rule that out.
    It does tramline like a B*****d when the road surface is uneven.
    Could it be that there's some wear in the suspension bushes ?
    Any ideas, has anyone suffered/suffering the same ?
    [Ex]Admin Duncan's Avatar
    All springs intact?, and shocks in good order?
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    All seems ok.
    WGAF#5
    what was the road like Phil -
    flat - asphalt - tarmac ??
    main road - a class b class c class ?
    last time it rained in the area ?? was the road greasy ??
    tyres - new worn - make model pressures etc
    all could be contributary factors
    if your still concerned after ruling out the above
    - find a quiet flat road someowhere (old airfield - industrial estate) and try and replicate the braking conditions that applied and see if you get a similar imbalance - if you do maybe a caliper sticking - worth taking to a garage and asking them to do a MOT brake test on the rollers to see if theres an imbalance
    spoons
    Guest
    + Tyre Pressures Correct?
    + Whats the tyre tread depth like at the front? (check all over the surface, inside edge and outside edge)
    + Did you brake in a dead straight line? or were you turning slightly when braking?
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    I'm happy its not the brakes but the tyres are about 2mm shy of the wear bars. They are Bridgestones Potenzas @ 38psi iirc.
    The road was a good flat 'A' road and was bone dry.
    Quote Originally Posted by spoons View Post
    As said Steve, 38psi iirc and breaking in a dead straight line on flat even road surface.
    spoons
    Guest
    Quote Originally Posted by FIL 4822 View Post
    I have 42 Psi in the fronts and 38 psi in the rears. Dont know what a 2.0Turbo needs?
    Very strange, I'd be inclined to check the shocks and springs (especially knowing how easy the Vectra springs snap)..
    Time to get rid of it in my opinion.... go get a nice VXR instead
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    I had 38 rear and 40 front, but when i mentioned tramlining, it was recommended that i drop the fronts to 38.
    I'm going to put the fronts to 42 at see how that goes.
    No VXR for me Steve, i want a BMW 530d Touring and keep the 2.0T as my ongoing modifying project .
    spoons
    Guest
    Well I notice a massive difference on heavy braking if the pressures fall below 42 psi on the fronts. The car twitches all over the place...
    If you want to get rid of tramlining, switch to 18" Alloys and tyres, I dont get any tramlining ... keep the Snowies for show... get some nice light racing 18" alloys for playtime..
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Is it possible there's a brake imbalance? Maybe one caliper not as free as the other 3?
