Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 111
Thread: Z19DTH symptoms of a misfire issue
    mansfield
    Default Z19DTH symptoms of a misfire issue
    I have a 1.9 cdti (150) vectra 04 plate.
    The problem started off quite intermittant but have gradually got worse,
    upto yet i have changed and done the following (in no particular order):
    1. full service (inc all belts)
    2. Throttle control unit
    3. Throttle pedal
    4. Intercooler
    5. egr valve
    i have Opcom, tried doing live readings as the car is being driven but the car is wise to that and then does not play up
    once the car has had its moment and i get home the code that always comes up is P0638 - 04 (electronic throttle control circuit open)
    the code will clear but as soon as the isuue happens again it brings this code back up.
    i have tried all i can think of.
    Anybody try and shed a light on it?
    Steve
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    3rd injector...?
    Very common and will cause misfires.
    mansfield
    ahh forgot i had done that too, will ammend the list above (just realised i cannot)
    Lancashire
    Trim : XP1
    Mileage : 66000
    What did you do with the EGR, replace it with a new one, or clean it...?
    mansfield
    replaced it completely, since the new one has been on i have also cleaned it too
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by ste_goffy View Post
    I only ask as I had this issue and tried two brand new EGR's and it cured it for a short time but never removed it.
    mansfield
    mine also cleared after i replaced the throttle pedal for about 2 weeks and then started coming back again, but as you say never cured the problem
    Lancashire
    Trim : XP1
    Mileage : 66000
    Did it cure it at all when the new EGR was fitted..?
    mansfield
    for a limited time
    Lancashire
    Trim : XP1
    Mileage : 66000
    for a limited time
    Exactly the same has mine, I blanked my EGR and its never done it since (over 1000 miles now).
  1. Z22YH misfire issue
    By dansoarr in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 18:40
  2. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
  3. EGR symptoms
    By tobybongo in forum Engine & Drivetrain
    Last Post: 12th October 2008, 21:32
  4. dmf symptoms
    By tommy tess in forum Engine & Drivetrain
    Last Post: 30th May 2008, 21:14
  5. Symptoms Of Being Over 25…..
    By Inspektor in forum Comedy & Humour
    Last Post: 22nd February 2006, 15:47
z19dth misfire
ecu xc57
z19dth 3rd injector symptoms
vectra fe15 fuse
p0638 electronic throttle control low voltage
z19dth misfire in cold weather
z19dth intermittent misfire
