Thread: radio not working
    Jul 2010
    hartlepool
    Default radio not working
    hi,
    my radio not working tryed the fuses but there okay theres no power at all going to the radio can any one help with this ???
    milton keynes
    Quote Originally Posted by neil.r View Post
    hi,
    What year is the car?
    what stereo is it?
    do you have illumination if you turn the lights on?
    Jul 2010
    hartlepool
    Quote Originally Posted by kman247 View Post
    what stereo is it?
    my car 2005 cdr 2005 vdd i have no illumination when lights are on
    11 Post(s)
    Have you also checked the fuse on the back of the stereo?
    Jul 2010
    hartlepool
    yes i checked them
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You say that you've checked the fuses.
    You are aware that the radio is affected by fuse numbers F1, F7, F9, F10, F12, F17, F19 and F26 at the end of the dash panel.
    I also assume that you have checked that the headunit and display are also connected up properly.
    If power is not getting to the head-unit, then you nay need to test the connections with an AVO (analogue voltmeter / ammeter)
    Digital test meters can damage the vehicles electronics. The pin out is on the sticker on the head-unit casing.
    I would be tempted to say fuses first, then a fault with the main looms or their connection.
    If voltage is showing on the conductors, then it must be a headunit fault.
    At risk of being repetitive - check fuse F12 at the end of the dash panel.
  1. Radio on/off button not working
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 15:03
  2. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  3. Radio code not working!
    By animal22 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 22:00
  4. radio controlls not working
    By neverlandandy in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2010, 17:16
vectra c radio not working
vauxhall radio not working
vectra 2003 diesel radio not working
my vectra radio has stopped working
vauxhall insignia radio not working
2005 vectra c radio not functioning
opel vectra 2002 radio virta
vectra c no radio
vauxhall vectra 2008 radio stopped working
vauxhall omega no power to radio
2004 vectra c stereo dead
vauxhall astra 2011 radio not working
opel astra radio not working
opel vectra 2002 gts No Power to radio
vectra c gts No Power to radio
my radio has stopped working in my Vauxhall vectra
zafira 05 radio not turning on
vectra car radio wont turn on
jr vectra radio stopped working
vauxhal astra 2010 sterio not working
opel c radio not working voltage is
vauxhall astra 2002 radio not working
problem sa radiom vectra c
opel vectra c radio stopped working
vectra c radio not illuminating lighting up
