Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Engine rebuild and now in limp mode
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    81 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default Engine rebuild and now in limp mode
    some of you may have read on my earlier thread that i was rebuilding my engine due to burning oil, well the rebuild was completed and engine turned over with the coil pack disconnected until i was certain there was oil pressure,
    i ran her a few times letting her getting up to operating temp before taking her out today and talk about hold back, there was no eml and will not rev past 4000rpm, i know i should not be reving that high till its run in but it was only quickly to see if it was limp home mode, i should also say that previous to the work the car was starting almost straight away and now is taking 8-10 seconds of cranking before starting. but when it is started it ticks over fine
    i read the fault codes this evening and i got the following
    P0335 - Crankshaft Position Sensor "A" Circuit Open
    (04) - Present
    the only time i touched the crankshaft sensor was to clean a load of grey sludge and metal filings off of it
    Huddersfield
    Have you disturbed the wiring to it instead.
    Swanley , Kent
    81 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by Paulrushton View Post
    the whole engine loom was removed whilst i was doing the work, however all the connectors are back on,
    i have checked the connections and they seem fine and everytime i clear the fault codes this one will not clear
    Swanley , Kent
    81 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Hi all i fitted a new crankshaft sensor today but it is exactly the same , it does not matter whether the sensor is plugged in or not it is still the same,
    i tried tracing the wires to check for continuity but have found nothing, there is a brown with blue stripe wire that connects to loads of other same colour wires and then goes off to practically every sensor on the engine and a brown with green stripe that dissapears into the main car loom , but even checking continuity on that wire shows no problems.
    i have tried numerous times to reset the dtc,s but this one will not clear and im getting really peeved with the car now, i hav''e only had it 4 weeks and already it has had the following
    maf sensor
    crankshaft sensor
    thermostat housing
    set ofplugs
    10 litres of oil
    oil filter
    head gasket set
    new piston rings
    air filter
    pollen filter
    sump plug
    what else can it throw at me???????
    Swanley , Kent
    81 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    I have ruled out the cam sensor as the car wont start with that disconnected , i just dont know what else to do, i cant afford to keep throwing money at it
    Lancs
    Most vehicles will run with only one engine speed sensor, as yours runs with the crank sensor disconnected, but will not run when the cam sensor disconnected, this would indicate that the crank sensor or wiring is at fault, as per your code reader.
    Was the new sensor from VX or some spurious brand?
    I had a non VX cam sensor fitted once and it was worse than the original, loads of errors, got a genuine VX one job done.
    Swanley , Kent
    81 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by hippyguyman View Post
    it was a genuine vauxhall part, i double checked everything today including timing and everything is spot on,
    Lancs
    Have you sorted this yet?
    Everything still points towards a faulty crank sensor/wiring. It is possible the new sensor is faulty, found these instructions for testing the sensor.
    Testing with a voltmeter: Set your voltmeter to Ac Volts. You can connect the probes to the 2 terminals of the sensor. It doent matter which way around as it is alternating current. If it is a 3 pin sensor you need to find which one is the screen. This will usually show continuity to earth when testing with the meter set to ohms. A cranking Engine will show approximately 0.5 - 1.0 volt. A running engine will show approx 2.5-3.0v volts Ac
    north east
    The crankshaft sensr gets its reading from a toothed wheel, if the teeth have filed off or damaged the sensor isnt able to read it, id take the sensor out and check the conditiong of the wheel with a torch, if is damaged or dirty is probably time to drop the sump and inspect closer.
    WGAF#5
    has the sensor been remounted correctly -the timing will only work in one position - if the timing has not been set correctly with the sensor then you would get this message - sealy do a timing kit which incorporates about 3 lock off times to get the timing exactly right - there kit is £500 so its obviously important that the timing sensor is set correctly
    chances are its not hence the message
  1. Lumpy engine then limp mode
    By themarbleman in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 20:17
  2. Replies: 0
    Last Post: 8th July 2010, 18:17
  3. Intermittent check engine light and limp mode
    By Loaf in forum Engine & Drivetrain
    Last Post: 16th April 2010, 10:43
  4. 2.2dti engine problems and limp mode
    By the_wave_rider in forum Engine & Drivetrain
    Last Post: 21st September 2009, 17:45
a20dth engine rebuild forums
