Thread: alarm help
    South London
    Default alarm help
    Hi
    my alarm keeps going off about every half hour.
    I have removed the sounder but now the horn goes off instead.
    How can i disarm the system until I cure the problem, and has anyone any clues to fix the problem?
    Thanks for any replies.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Have you tried unlocking the car manually? i.e. buy sticking the key in the lock? Only other thing I can advise is to open and close all door, including the bonnet just in case its something simple like dodgy switch.
    South London
    HI
    yes I have opened and closed all doors and the bonnet but it still goes off.
    If I lock the car with one press of the button, so not setting the deadlock, is the alarm not then activated.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    how about checking the above then making sure all the windows are right up, check for large foreign bodies in the car!, moths,flies,spiders, flying or crawling and setting the sensors off, you may even have a drain on the battery that may be setting it off ?? if that's possible ?.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by FRANKA View Post
    HI
    yes its activated, the dead lock prevents or supposed to! someone opening a door after breaking the glass by reaching in then just lifting the door button.
    South London
    I have just checked the battery in the key.
    The voltage is pretty low. I dont know if this is the problem but low key battery voltage can cause some strange effects.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i meant the cars battery! i didnt make that very clear sorry.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    why not press the button in your car that disarms the sensors, then lock your car normally using the keyfob, hopefully then the alarm wont go off. this will give u a rough idea as to what the problem is. ie motion sensors or the boot, bonnet, door sensors, tilt sensors etc etc. hth.
    PaZ!
    South London
    Thanks for all of your replies at such a late hour.
    Wizard, you were clear about checking the car battery voltage but I do know that a low key fob voltage can produce weird effects on the car electronics.
    The answer from badboy is an excellent suggestion and if the alarm still goes off now the keyfob battery has been changed that is my next step.
    Once again thanks for all your replies, that is what makes this a very friendly and great forum to belong to.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Dont forget the other suggestion made above. Press the button on the dash to disarm the sensors.
    This will further eliminate certain areas
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
