Thread: Vectra 8v 120 cdti....Belt replacement?
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default Vectra 8v 120 cdti....Belt replacement?
    Does this have a chain or timing belt.....also when do they usually need replacing??
    I have a bad feeling mine needs doing......how can i tell if its been done and what sort of cost should i expect?
    PRESTON
    120's are belt driven, Vauxhall reccomended interval is 10 years/100000 miles, but its worth doing sooner, personally i say nearer 60k. You could release the upper cambelt cover and ease it to one side carefully, then look and see if the belt looks new. You cant remove the upper cover without first taking off the engine mount, but it will give enough to see. Possible cost £150 to £180 ish at independant, including water pump change.
    Jul 2009
    Tamworth
    Cheers barney, Guess im gunna have to take a loo at the belt.
    Anything to look out for or just the usual wear?
    Damaged sides and cracked teeth?
    PRESTON
    the cover will only move enough to see the flat side of the belt, so look to see it any printing on the belt looks unworn, this would indicate a recent belt change. if its all worn off, then it's likely to be original. Be on the safe side and get it changed soon as you can, 120's dont take kindly to snapped cam belts.
  1. Vectra Sri Cdti 150 belt noise???
    By CtiStu in forum Engine & Drivetrain
    Last Post: 15th July 2012, 18:19
  2. cam belt/chain replacement?
    By bigdan03vfr in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 09:50
  3. Vectra 1.9 CDTI cam belt change
    By bravenger in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 10:47
  4. When should i change my time belt on vectra 150 cdti
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 31st January 2008, 20:06
