Thread: USB.
    Mileage : 000
    Default USB.
    I was wondering if "they" make a (female) USB to 3.5m/m line in plug.
    I have the idea of using a memory stick ( full of music) to the Auxilary plug in Larisa,s car. Thjus the need for the above "adaptor" or lead. If one is made that is.
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Ed I think you'll find that the line in relies on audio signals being transmitted by an audio device and amplified by the HU, a memory stick transmits data in binary form for use by a computer etc to produce music from the data files I am not sure this will work.
    May 2007
    West Yorkshire
    as above, it wont work. The 3½ mm jack is audio input.
    Mileage : 000
    You might be correct Paul. But we have a portable CD/Radio player and it has a USB port. We can play music off the memory stick from there. I don,t know if the electrics inside take into account what you mentioned above.
    Mileage : 000
    Quote Originally Posted by sshooie View Post
    I understand where you both are "coming from" now. It was worth the thought though.
    Looks like I will have to buy her the MP3 Player instead. Mind you it was my idea to get the MP3 Player for her to use in the car.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Hmm. if you do decide to try it, Maplins do all sorts of peculiar connections.
    Regular Member Exclusive BV's Avatar
    West Midlands
    I know what you mean. My previous stereo has a USB input as well as aux in and several other inputs.
    The aux in as previously stated just accepts analogue audio input. The other inputs USB, SD etc have the built in circuitry behind them to accept digital input. The two are not normally interchangable.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The USB stick needs a power feed from the socket it's plugged into to bring the chip inside to life, you don't have enough connections on the 3.5mm jack plug (three max on a stereo one) to send power and earth one way and audio back the other.
    Mileage : 000
    Sounds like it is a No then. Cheers for all the replies.
