Thread: car died today
    glasgow
    Default car died today
    hey guys, the bus died today, started to tick over very lumpy(like a v8) then there was no power at all then just cut out. look a while to start again. funny thing is its running fine again. just strange that it stalled cause its an auto.
    any ideas guys??? should i be cleaning the egr valve and the boost valve??
    PRESTON
    start with cleaning the egr and boost sensor,check all the vac pipes and make sure the swirl rod is attached correctly. coz its an auto it will have a diesel particulate filter in the exhaust and when doing a regen, the engine can seem lumpy at idle. Once all things checked, take it on a fast hot run to see if it clears the dpf a little. If the dpf is blocked or blocking, the engine will stall.
    when was it last serviced? could also be the fuel filter blocking.
    glasgow
    cheers barney, will give it a go tomorrow,
    think it was serviced just before we got the car but another 1 wont hurt it
    glasgow
    well new diesel filter fitted today, but problem still there, going to clean the egr valve and boost valve tomorrow and see how things turn out.
    glasgow
    cleaned egr valve today but problem still there, prob say its worse now, any ideas guys?
    preston
    Was it cold when it died or hot after restart??
    have you checked your fuel filter housing for leaks / poor seal and make sure the fuel hoses are held in place properly
    glasgow
    just cleaned boost sensor, and took the bus up the motorway. Inst consumpt jumped to 0.8 gal/h at idle. Car feels better but when the ins consumpt jumped was it doing a regen???
    preston
    might have been doin a regen
    try a couple of tanks of V power diesel to give it a good clean through
    hope you've solved the problem
    is it back to normal?
    glasgow
    so far so good. been out and about today using the car as per usual, been to the parents(miles away) and no problems yet.
    glasgow
    Problem now fixed, think it was a comb of boost sensor,egr valve and diesel filter. All of the above were black so a good clean out with carb cleaner looks like it worked.
    The how 2's were a great help showing where and how's best to get at items. Hats off to the people that put the how 2's together.
  1. car finally died today
    By jsud2002 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 17:21
  2. 2.2 Dti Died today need help !!
    By elongmoss in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 18:08
  3. Tiny died today!
    By NellyD in forum General Chat
    Last Post: 28th July 2008, 22:19
  4. What a **** today! Mushy and his Siggy nearly died!!!
    By mushy2007 in forum General Chat
    Last Post: 3rd April 2008, 21:13
  5. the real soulman died today
    By soulman in forum General Chat
    Last Post: 26th December 2006, 19:55
