Thread: what price for a dealer to insp for chain rattle?
    Jan 2010
    glasgow
    Default what price for a dealer to insp for chain rattle?
    rite i have a what sounds like a rattle or chain tensioner sticking on start up wen cold or nearly cold now the car is under a 2 year warranty has any 1 paid a main dealer to do a eploratory insp to see if they had a chain rattle? and if so how much was it?on the 2.2 direct engine, now in my warranty book it says under whats covered engine wise wont post it all but says timing gears,chians and belts, rite now this is my thinking under whats not coverd this is the bit thats getting me ,thinking they will use this a get out clause, wear and tear ,corrosion,seizure or deterioration. has any 1 had them saying that? ok i know if i say go f your selfs they have to put it back the way it was, now the cars a 07 plate i got it with 22894 miles on it and its now at just over 28k miles so i have done just over 5k miles had it just over 6 months it had a main service at 21639 miles or so the stamp in the book says ,do u think there going to pull the its the tensioner sticking its not covered stunt? as if its £100 to do a insp to see if it is im down £100 and still in the same boat lol what do u think guys?
    Glasgow
    Hey there, the dealer will charge you an investigation charge typically an hours labour which will probably be around £60. If its still within the vauxhall warranty as a new car and the chain/tensioner is faulty then you should get a new one without problem. If its a used car/aftermarket warranty you have purchased then there is little chance a warranty company will cover it until or if it fails. HTH.
    Jan 2010
    glasgow
    its a used car bud 07 plate and its a autocare warranty i think its a 4-6 hour job time or so in the dealers eyes anyways lol id rec around £120 they would prob want to insp it just to say its a tensioner seizure thats causing the prob and its not coverd in your warranty, thats £120 or the likes towards some 1 fitting a chain kit for me lol
    Jan 2010
    glasgow
    think i will give it a oil change see if it helps any it may just be taking its time to get round hence the whirr/rattle for the first few sec on start up fingers crossed
    Glasgow
    Ive got the autocare warranty aswell, the investigation charge is around £60 after they have it they will tell you if its needing done or not they wont take anything else from you for looking at it. If its covered under warranty then you wont have to pay the investigation charge.
    Ive had loads of work done through my autocare warranty but unless it fails i doubt they would change the tensioner although its worth a try also as its not long out of vauxhall warranty i would tell them to contact VX and ask for them to pay for it to be replaced if autocare wont pay for it.
  1. 2.2 direct.timing chain rattle.
    By Dobs in forum Engine & Drivetrain
    Last Post: 4th April 2012, 20:47
  2. Timing Chain at Vauxhall Dealer
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 18:57
  3. 2.2 cam chain death rattle
    By Big Dave in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2011, 00:19
  4. chain rattle back
    By bundy b in forum Engine & Drivetrain
    Last Post: 18th May 2009, 17:41
  5. timing chain rattle
    Last Post: 27th June 2007, 20:06
