Results 1 to 10 of 11
Thread: clearing error codes
    Regular Member shadow.warrior's Avatar
    Jul 2009
    Melbourne
    Default clearing error codes
    Hi Guys.
    I have replaced a faulty sensor. But the check engine light is still on. Is there a way to clear/reset the error codes without leaving the battery unplugged all night?
    i tried turning the key on and off 25 times, but this was a waste of time.
    Mileage : 000
    After quite a while the code if it is regarded as historic, as it should be when the faulty part is replaced. If you wait a while longer the fault code should disapear.It might take a while as I say.
    Jul 2009
    Melbourne
    but i need it gone now to see if the new sensor has in fact resolved the issue. if not then i need to replace something else. which is highly likely.
    Mileage : 000
    You need a code reader then, one that will erase the fault code. As far as I am aware there is not a !quick" way to do it without the "tools" "ie" a code reader.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Disconnect the battery for 15mins, that should clear any lights on the dash, just make sure you have the code for the radio
    PRESTON
    either a trip to the stealers or get yourself a code reader that can read and reset fault codes, probably a good thing to have anyway as a Veccy owner.
    Regular Member LADmachining's Avatar
    Hampshire
    If the light is still on, then the fault hasn't been rectified.
    When a fault goes 'not present', the code is still stored but the engine management light will be extinguished. It is at this point that 30 ignition on/off cycles will clear the 'not present' code.
    Disconnecting the battery won't make any difference if the fault is still ocurring!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    EML light will come on when car is started if there are stored codes, disconnecting the battery will clear any stored codes I think you'll find. Obviously if there is still a fault then eml will still show but at least by disconnecting the battery you are eliminating stored codes
    Hampshire
    But depending on the nature of the fault, the codes can re-appear as soon as the system is powered-up and the ECU runs diagnostic checks on the connected systems and sensors.
    Jul 2009
    Melbourne
    thanks for the help guys. i think i might fork out and buy a code reader.
    the best deal i have found so far is: $88 for a serial connector(need serial to usb converter to connect it to laptop). The sw is free. It updates in real time and shows you all sorts of interesting read outs. Can read and clear codes too.
    http://www.obddiagnostics.com/
    has anyone had any experience with it? is there any others worth looking at before i buy this?
  1. error codes
    By bellstephen in forum Troubleshooting
    Last Post: 21st February 2012, 17:16
  2. Error codes
    By Ziggy in forum Engine & Drivetrain
    Last Post: 17th February 2012, 14:26
  3. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  4. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
  5. Clearing fault codes
    By oxenburger in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 17:59
