Thread: Asking if anyone might be able to help.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Asking if anyone might be able to help.
    I've had them on my watching section of ebay for nearly 2 months now but i've finally done it, i've just purchased a set of FK AK coilovers for the GSi. I'm glad in a way i waited now as they had them up for £298.99 (which i thought was cheap) but on Thursday they reduced the price to £188.95. Now when it comes to major stuff like suspension i'm useless so what i'm asking is there anyone that can fit them for me once i get them, i don't mind traveling (to a certain extent) and i'll sort you out with some cash.
    If anyone could help me i would be very grateful indeed.
    Cheers Dave.
    cambs
    hi m8
    if you cant find any one closer i'll give you a hand
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Always help down here too
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Thanks guys, like i say i'm very limited to what i can do but always willing to try.
    cambs
    Quote Originally Posted by Hyperhart View Post
    not a problem m8
    but you might want to buy some more drop links as mine were pigs to get off and had to cut mine off.
    and i am in wisbech
    Regular Member johnynoi's Avatar
    Jun 2009
    Dundee
    Id second that, by the time i'd wrenched my droplinks off they were gubbed, can get new ones cheap enough on the bay, I was £23 this morning from a local factors but needed them sharpish!
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    So should i get new droplinks anyway even if they don't need to be changed.
    Is there anything else that people would recommend to change whilst doing it, what about on the rear.
    Jun 2009
    Dundee
    Yeh id get them anyway, your going to be taking the top bolt out of them anyway so be as well replacing them while the wheels are off. They were also the hardest bolts to remove when i did them last week so i'd give them a good spray a day or two before you do it!
    Rear should be ok, just remove the bolts holding the shock in (the bottom ones a pain) and the bolt on the rear axle closest to the rear of the car. The "how to" on here has more bolts than that removed but i found just removing that one was enough to get the spring out.
    A trick we found was to use the wheel nut bar in with the spare tyre as a kind of "L" shaped breaker bar on tge end of the ratchet as we couldn't get the bolts off with just the ratchet as we were weaklings! And there isnt much room to get any force on the bolt on the bottom of the shock
