Results 1 to 10 of 23
Thread: Air Filter Advice 2.0T
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Default Air Filter Advice 2.0T
    Ay Up Again Fellow veccy lovers.
    Need some advice on upgrading my Air Filter.
    I Have been told that by changing from a standard air filter to a full induction kit will cause problems with the Air Flow Sensor.
    Is This True?
    I'm Sure a lot of you guys have got upgraded induction kits and have had no problems at all.
    Any advice on which induction kit to go for? Im eventually gonna change the exhaust, and have the car remapped, if this makes any difference to the air filter you suggest,.
    All Advice Greatly Recieved!!!!
    Cheers. Mitch.
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Looking forward to seeing some replies on this, as I also am looking to upgrade my standard air filter on my 2.0T (Bsr stage 1)
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I run mine with a universal Ramair closed induction system, I removed the airbox and it connects directly to the maf (never been an issue with that at all). The intake end connects via some 80mm flexipipe to a VXR intake which i put on as its way shorter than the standard snorkel that was fitted.. With this set up I do not get any heat soak but plenty of cold air flow. Am not sure if you get a BHP increase, in fact i doubt it with any filter upgrade, but cleaner acceleration is noticable.. Also I get a gorgeous amplified turbo whine and dump whoosh......
    Ramair system about 45 quid, 80mm diameter flexipipe about 20 and the VXR intake about 25, think i got all the bits from the bay of E
    Aug 2009
    Yorkshire
    Quote Originally Posted by Caveman_nige View Post
    Thats all good when your a Pro like yourself, LoL
    Dont forget I'm a newbie who has never modded my car before!!!!
    You got any pics of it m8??
    Jun 2009
    South Coast
    no pics i can load up today at any rate.. I think Marcosuk put pics up, he ran with almost the same setup and had the same results.. its very easy to do, no tech skills required, honestly..
    http://ramair-filters.com/carb-race/...carb-race.html
    like this, but this says its for a 1.8
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item5adaffc761
    Aug 2009
    Yorkshire
    Anyone else with an induction kit on there 2.0t Veccy?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Pretty sure that Dez (Deztroyer) had a BSR optiflow on his 2.0t signum
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    I have a K&N panel filter on mine, have the airbox mod done and matched to the BSR stage 1 map, i had 243 BHP last time out on the rollers.
    Aug 2009
    Yorkshire
    Quote Originally Posted by FIL 4822 View Post
    Does this give any better engine noise having it this way?
    Do you know where the thread is on how to do the airbox mod? tried searching but think i must be blind..... LoL
    Tyneside
    I had a K&N Apollo fitted to mine and it indroduced a slight hint of turbo lag, but as Nige said the noise from the recirculating dump valve was amplified and sounded very nice indeed, but I ended up selling it due to the lag it introduced.
  1. Replies: 5
    Last Post: 3rd January 2013, 21:56
  2. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  3. 1.8 Oil filter advice needed.
    By Saulty in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2009, 18:45
  4. Fuel filter advice
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 13th August 2008, 09:32
  5. Any advice on removing & replacing Fuel Filter ??
    By Cilldara1 in forum Engine & Drivetrain
    Last Post: 2nd July 2007, 07:17
Vectra c 2.0t air filter
vauxhall signum 2.0t air filter
Tags for this Thread
