Results 1 to 10 of 13
Thread: hand brake noise problem
    Feb 2009
    doncaster
    Default hand brake noise problem
    got a prob when i pull on my handbrake every so often it makes a god awfull noise ,like a really big clunking noise but not all the time .sounds horrible and wondered if you guys could help,would it be covered under the warranty aswell, thanks for your help guys
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    What year is your car and has it had the handbrake lever spring recall?
    Feb 2009
    doncaster
    it is a 2008 vectra and no it has not had one since i have owned it ,cant say for the other owner .had a spring fitted on my other vectra but it was a 2002 one
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by pmitchell View Post
    Not uncommon this mate, I get the same with mine from time to time is seems to be to do with the auto adjuster in that, as the rear brake pads wear, seems like the piston in the caliper is a bit on the slow side to wind itself out a bit to compensate (at least that's my theory!!) what I tend to do is , with the engine running, pump the pedal a few times then keep it pressed and yank the handbrake up and down vigorously a few times and this sorts it for a while , until the next wear stage!! but certainly know what you mean by the noise it makes , sounds like something has or is about to break!! when it does it HTH
    Cheers Pete
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Is this noise coming from the handbrake lever in the car?
    Feb 2009
    doncaster
    yes when you pull it on you can feel it through the handle and makes a god awfull noise,will this be covered under warranty
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Mine does this too. Sounds like its slipping off the ratchet doesn't it? I keep expecting it to slip off completely. Does anyone here know if this was part of the handbrake recall issue?
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yes just had mine done mate had te same pro sorted now was 2003 to 55
    Feb 2009
    doncaster
    what did they say the prob was mine is a 2008 ,would this be the case fro mine .what did they do to stop it
    slough
    Just thought I'd mention that the return spring I don't think with cure the horrible handbrake noise, as mine has been done and still makes this noise from time to time as mentioned in my earlier post, it would appear that all the spring does is to ceate a tighter fit as it were to the ratchet assembly to help it lock more securely onto the ratchet teeth.
    Cheers Pete
  1. Hand Brake Needs Tightend
    By Tank988 in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2013, 05:17
  2. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  3. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
