Results 1 to 3 of 3
Thread: Unusual behavior from my poor CD30
    Regular Member babisskg's Avatar
    thessaloniki,greece
    Default Unusual behavior from my poor CD30
    Any ideas about the following . My CD30 ( Vectra C ) can't increase volume
    from a certain point and above . That means you open the radio for example
    you can hear the music and if you turn the wheel to open up the volume give's you nothing . Any suggestions ? I didn't change anything from the settings .
    Thank you in advance .
    babisskg
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Probably just a technical fault.
    Try pulling the fuse, or better still completely disconnecting the battery for a couple of hours.
    This will do a cold reset of the whole infotainment system (screen and head unit).
    90% of the time this cures the problem
    Faulty CD30's tend to turn themselves back on in the middle of the night and so flatten your car battery.
    This sounds just like a little momentary fault of the screen or head-unit, so should be nothing to worry about.
    thessaloniki,greece
    Thank you for the response . The problem appeared after lefting the car
    under extreme sunny conditions for 6 hours . It dissapeared next morning
    as it never existed . I will have in mind your advice . Thank you again.
    babisskg
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Vectra 2.2 Direct Petrol - strange behavior
    By rodzynx in forum Engine & Drivetrain
    Last Post: 18th July 2011, 15:30
  3. cd30 poor sound
    By kirky4ever in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2009, 14:40
