Thread: good morning
    Jul 2010
    croydon
    Default good morning
    ive got a problem , how to open the bonnet on vectra c without using the realese handle ( the realese cable had snapped or come off) do i need to remove the bammper or is there any other way of doing it????
    am a proud owner of vectra c 04 reg diesel
    thanks badger
    PRESTON
    they usually snap at the handle end, can you see the inner cable and maybe get some mole grips on it? other than that i'm not sure, but i'm sure someone will be along with the answer
    Jul 2010
    croydon
    i checked it and it doesnt seem that it snaped at the handle end ,is it possible for the cable to come off the realese mechanism under the bonnet???? cheers for the reply
    PRESTON
    found this in an old thread from 2009, it might help,,,,,,,
    1. remove front bumper
    2. undo the bottom radiator mount bolts
    3. get your hand up the front of your aircon rad and pull the half rubber, half plastic cover as far towards the front of the car as you can (its the cover which covers the bonnet release mech)
    4. use a torch with your left hand whilst lying on the ground. look up from the bottom in between your radiator and intercooler (if fitted). if you have moved the plastic/rubber cover correctly you should see the striker.
    5. with your right hand and a long screw driver go over the top of the radaitor with it whilst looking from underneath, you should be able to work the catch spring.
    best to have the car jacked up and dont smash your grille because it wont help much.
    Mine is a diesel petrol setup might be different.
    here's the thread http://insignia-owners.com/forum/showthread.php?t=93454
    Jul 2010
    croydon
    cheers for the reply ive already removed the bumper, and now it time to get the rest it good to be a member
    PRESTON
    was just thinking, this wouldn't work on a facelift as you need the bonnet open to get the bumper off, so maybe on facelifts the only way is to smash the grille,
    New Member chris dunning's Avatar
    Broseley
    Thumbs up Bonnet wont open !
    Went to open my bonnet only to find the release lever very slack. Rang dealer who said to bring in and pay us £60 to remove undertray and release catch with a long rod. Decided to have a go myself ! You can actually feel the catch if you have thinish arms and wrists. We used a 6" length of welding rod with a hook shape bent on the one end. Its not easy but it is possible. The bonnet released eventually and i then noticed the cabe was very slack. You must remove this slack by undoing the cable clamp (T25 screw) and sliding the cable until there is no freeplay at the lever in the car.
    It was the nipple that had popped out of the eye and not broken thankfully.
    Moral : check the freeplay at the lever regularly !
    Jul 2010
    croydon
    horayyyy ive done it . it wasnt easy but wit a help of my lovely missues who held the radiator forward so i could put my chunky arm thru and pull on the spring and release it. we have done it . by the way i went to a dealer yesterday with a question how to do it cos i was stuck. all ive heardwas ( we dont give information about how to do stuff on your car) VERY HELPFUL NOT. its good to be a DIY able cheers for all the help .
  1. Hello, Good Morning :)
    By sarah4vectra in forum Introduce yourself.
    Last Post: 30th September 2011, 16:42
  2. Hello, Good Morning & Welcome!
    By tyre_tread in forum Introduce yourself.
    Last Post: 14th February 2010, 14:45
  3. Good Morning
    By TonyP2020 in forum Introduce yourself.
    Last Post: 16th December 2009, 21:50
  4. Good morning
    By ed taylor in forum The 'Off Topic' room
    Last Post: 27th December 2008, 08:02
  5. Good Morning...
    By spoons in forum General Chat
    Last Post: 2nd September 2007, 10:33
vectra c bonnet stuck vectra c owners site:www.vectra-c.com
