Thread: Camber? Camber Kits??
    Jul 2010
    Londonderry Northern Ireland
    Default Camber? Camber Kits??
    Is there anything like this available?? Lowered the girlfriends car on thursday and the rear wheels have cambered slightly more than usual
    Regular Member hagga's Avatar
    kingswinford
    the rear camber can be adjusted slightly as the bolts are cammed.. but not sure if theres enough to bring it full to spec.. also need to be done where they have equip to check.. I'd leave it as is
    Jul 2010
    thanks mate, just wanted to make sure
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    I would highly recommend 4 wheel alignment after lowering. Camber on the rears will more than likely need adjusting as they are renowned for wearing the inner edge prematurely if not set coorectly. I would advise it being set as near vertical to spec on the rears as it will help to tyres.
    Jul 2010
    there isnt very much adjustment though
    spoons
    Guest
    Just to update this...
    Hapsdoggen from VXROnline.co.uk bought a rear camber kit from Australia...
    http://www.k-mac.com.au/
    I'm looking into this at the moment for my coilover kit
  1. bad camber!!
    By wullie-t27 in forum Handling & Braking
    Last Post: 9th November 2012, 21:06
  2. Problem with camber!!!
    By stewartvectra in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 21:46
  3. camber kit
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 09:23
  4. camber
    By linley85 in forum Handling & Braking
    Last Post: 30th November 2008, 15:05
  5. Camber
    By Daywalker in forum Handling & Braking
    Last Post: 22nd June 2008, 10:46
