Results 1 to 10 of 14
Thread: Z18XE not quite right....?
    West Midlands
    Default Z18XE not quite right....?
    Some days my car is a joy to drive - feels light & nippy. Other days (like today) it feels like a big lumbering dog.
    It goes reasonably well and fuel consumption is OK, pretty sure brakes aren't binding, but it just feels a bit heavy & tight. I've cleaned out the throttle body tonight and run some carb cleaner through it too as the inlet manifold looked a bit manky, still doesn't feel 100% though. The breathers looked fine.
    Twice since I've had it (5 & a half years) its got through a tank of petrol so fast I thought it had a leak, but the next tank it's gone back to normal, not sure what that means.
    I service it regularly and its had new plugs & air filter recently. I did the accelerator/brake fault code check thing tonight and it came up with no faults.
    Any ideas what I can look at next?
    Cheers.
    Sep 2009
    Audley STAFFS
    I had a similar problem with my 1.6 vec some years ago,, it was the HAND BRAKE not quite releasing, not enough so the disc's were getting hot, but enough to notice, also if the fuel tank is full you may notice a difference, as when there is only a couple of gallons in it, remember the rear discs have two sets of pads,
    Sep 2009
    Audley STAFFS
    I will give this a bump incase anyone has a better reply than mine.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Are you filling up at the same petrol station all the time?
    I notice a difference with my Z18XER when I fill up at a particular location it's quite sluggish on that tank and it seems to use it quicker
    Just a thought
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Quote Originally Posted by CLOMP View Post
    Puzzled.. as our 55 reg Facelift C with the Z18XE engine has only one set of pads on each rear disc/wheel & has no separate 'auxillary' small rear drum with 'shoes' for handbrake parking use..
    The handbrake operates a lever on each rear caliper closing each single set of rear pads onto the disc for parking...ie the rear pads are used for normal braking & parking...& as I understand one reason why there's been a problem with the cars moving after the handbrake was applied for parking...Cheers
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The Vec C's don't have separate shoes and pads like the Vec B. As for the hand brake problems that was related to the actual handbrake lever its self falling and releasing the brake
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Fuel filter blocked maybe, just a guess. Could just be that as youve had it 5 1/2 years that youve got used to it. The 1.8 is never gonna be a flying machine. Ive noticed with mine that its not as torquey as my old Accord and if you dont get the gears right it feels sluggish too. If the brakes are binding you'll notice more brake dust on the wheel trims than normal, and if you coast to a gentle stop at a junction or traffic light without using the brakes you should feel a "tug" through the car as it stops.
    Nov 2007
    Quote Originally Posted by bcoss View Post
    Cheers.
    Have you checked the state of the spark plugs ????
    I give our 55 reg Facelift C (Z18XE engine) a dose of Wynn's injector cleaner for Petrol engines - the green label - twice a year when I fill up the tank...
    Iv'e used normal (97 RON) supermarket petrol (mainly Morrison's) about 90% of the time...
    Below is a photograph of the original Bosch spark plugs I replaced last year after 4 years of use & about 37K miles..not bad...
    I fitted 'Quad' electrode NGK BKR5EQUPA - (Long Life) plugs & still using the injector cleaner twice a year...
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Tony W View Post
    sorry to be misleading, I did the discs on my vec B, Myself. but a garage did the discs on my Vec-c, sorry for the confusion,,
    PS, if the fault was the plugs the fault would not be intermitant,,,would it?
    West Midlands
    Have dismantled & cleaned up the rear brakes tonight. n/s was fine but the o/s seemed a bit tight, although nothing terrible. Off for a fill up now, will report back...!
    ps. Plugs changed in the last 2 months.
    pps. Have also just done the airbox mod...!
  1. Z18XE using oil
    By damers2000 in forum Engine & Drivetrain
    Last Post: 5th August 2012, 11:48
  2. Z18XE using oil...
    By danBoy in forum Engine & Drivetrain
    Last Post: 24th April 2010, 10:41
  3. z18xe z18xer
    By pitsmoor21 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2009, 20:21
  4. Z18xe
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2008, 10:33
  5. Z18xe?
    By Matt21385 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2006, 07:48
z18xe flat spot
z18xe feels slow
z18xe using oil
