Thread: change my engine!!!
    Regular Member bedo13's Avatar
    Oct 2009
    EgypT
    confused change my engine!!!
    im looking for more power, more speed..
    my vec is 1.6 & im so depressed with it.
    which engine can i replace with?
    2.2 or 2.0 turbo??
    2.2 can be reforced with turbo??
    sorry another quest: spare parts for these engine are similar to 1.6 engine (belts & filters)
    what should i change with the engine ?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by bedo13 View Post
    the rest of the car......
    I seriously think it would be better to change the car, with more power yu will need better handling, brakes and probably a new loom... More trouble than its worth most of the time unless you really know what you are doing...
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    take it its a vectra b
    Oct 2009
    EgypT
    thnx for reply
    but changing the car will cost me alot and vect-c present here in only 1.6 engines, im in egypt.
    but i decided to change the engine & gear box, suspensions , brake system.
    Oct 2007
    Shropshire
    I think you can swap the 1.6 for a 1.8, straight swap, no wiring mods. (And yes the vectra c came in 1.6 form, just not in the UK)
    Full Member Big Sig's Avatar
    Changing the engine in most cases will cause a massive problem getting it to run as the ecus etc will also need changing unless you ran it with a stand alone ecu setup. Also the belts and filters are different in nearly all engines.
    It can be done but would probably be cheaper just to import a car from Europe!
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    push it woyld be faster lol
    Oct 2009
    EgypT
    here i cant import car with egine more than 1.6 , it will be very expensive about 4 folds..!!
    engine i'll swap come with its ecus compresor and all parts under the hood, but i ask about spare parts belts , filters etc which be changed regularly as only they only sell parts for 1.6 engine
  1. engine change help
    By ros46si in forum Engine & Drivetrain
    Last Post: 7th October 2012, 21:48
  2. How often do you change your engine oil?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 13:32
  3. dti engine change
    By driveryte in forum Engine & Drivetrain
    Last Post: 25th July 2010, 22:33
  4. had engine change
    By Nojustice in forum Engine & Drivetrain
    Last Post: 13th January 2010, 14:20
  5. engine change
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2009, 20:38
