Thread: Reset Engine Management Light
    Jul 2010
    Barnsley
    Default Reset Engine Management Light
    Hello Everyone,
    I just have a quick question about my engine management light...
    I would like to reset my engine management light. Now reading a few posts I do this by disconnecting my battery for 20 minutes. My first question, is this correct? The second question is that if I do this will it reset my onboard computer i.e. reset the milage and average mpg?
    I have also read that this will reset the ECU and may change a few things, is this advantageous or not?
    Any advice will be greatly received and thanks for taking the time to look.
    Cheers, Guy.
    11 Post(s)
    Yes, I think it'll reset the BC mileages to zero.
    Once you've reconnected the battery take it for a little drive. The ECU will learn your style of driving instead of the previous owners. Not sure whether it's advantageous or not. Depends on how the previous person drove the car.
    WGAF#5
    you will also need to reset the auto close on the windows if yo disconnect the battery and if yours is a preface half can network vehicle you would also need a radio code
    Jul 2010
    Barnsley
    Thanks for the quick responses.
    deztroyer - Its an '06 Vectra with a CDC40 Opera radio, not seen a code for this, do you think I will need one?
    Jan 2010
    wirral
    No ,
    You'll be ok.....pretty sure
    Jul 2010
    Barnsley
    Cheers boys, disconnected battery for 20 mins, everything was reset and no radio code was required. I think it has made it drive a bit more smoothly but that might just be psychological!?
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. ECU/engine management Reset?
    By northantswrx in forum Engine & Drivetrain
    Last Post: 1st October 2011, 21:46
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
vectra c engine management light reset
https:www.vectra-c.comforumshowthread.php115607-Reset-Engine-Management-Light
vauxhall corsa engine management light reset
vectra engine management light reset
vauxhall vectra engine management light reset
vauxhall astra engine management light reset
engine management light vectra c
vectra c reset engine management light
vauxhall vectra c engine management light reset
how to turn off engine management light on vauxhall astra
how to turn off engine management light on vauxhall vectra
vectra c engine light reset
vectra c eml reset
vauxhall vectra c engine management lightdo vectra c engin management light need to be resetcorsa engine management light resetReset engine management light vectra chow to reset engine management light on vauxhall astrahow to reset vectra engine management lightvectra c turn off eml lighteml light reset vauxhall zafira 2013how to turn off engine management light on vauxhall corsahow to reset engine management light vauxhall zafiravauxhall vectra 1.9 cdti eml light reset
