Thread: Signum pollen filter
    Jul 2010
    London
    Default Signum pollen filter
    Hi Folks,
    Can anyone help me identify where the pollen filter and drain pipe is on a 2006 1.9 cdti Signum? My A/C's stopped working and want to try this before re-gassing.
    I've looked all round the engine bay and can't see anything remotely like what's been described on other threads here. There is a small box with a clip release top next to the fuse box but to actually get the top away from the main unit it looks like you need to release the fuse box somehow as it's tucked underneath the top of the wing.
    Any info greatly appreciated.
    DaveMM
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    If you look from the front on the battery side at the top of the scuttle panel the pollen filter and drain is under that. You have to pull the rubber seal off and then you can lift the scuttle panel up to access the pollen filter. HTH
    The filter is easy to get to mate. Find your passenger side windscreen wash nozzle, and the plastic cabin air inlet part it attaches to. You'll see a seal holding that to the engine bay. This simply pulls off allowing you to lift up the plastic cover and the filter should by right in front of you...
    Jul 2010
    London
    Ahahhh thanks for that chaps, I'd never have spotted that in a milyon years.
    Dave
  1. Pollen filter
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 14:48
  2. Pollen Filter
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 21st July 2008, 22:37
  3. Pollen filter
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2007, 20:34
  4. Pollen filter
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2007, 14:11
  5. Pollen Filter
    By Merick in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2007, 19:26
