Results 1 to 10 of 11
Thread: Power in boot area
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Default Power in boot area
    Plan: Mount rearward facing in-car DVR in preface hatchback.
    Requirement: Discrete, ignition live, lighter/aux power socket ideally in boot area below parcel shelf, on left side of vehicle.
    Suggestions ?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Well there is a fusebox in the boot, on the left hand side, bound to be a switch live somewhere in there. Or just run a live direct from the battery, 20 minute job tops tbh.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well yes, I do know there's the REC in that area hence plan to have a socket not too far away. The more specific question is, has already fitted a boot power socket already and if so, what connects where?
    I'd rather not have half a mile of wire running the length of the car from the battery though.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    The reason I mentioned running a live front to rear direct from the battery is that If theres not already a power socket there that means your looking at taking your feed off a switched live that is already there. This mean that you will be putting extra load on that cable for something it was never designed for. Running a single live from the battery, to the rear, gives you a better chance of not over loading the original cable, or the fuse. You already have a mile of cable running around your car, another 3m wont make a lot of difference.
    Regular Member mic's Avatar
    Jun 2007
    I put a power point in my boot a couple of years back. Took the power from the fuse box in the rear so it is a permenant live. Just found the original thread here
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    That's a bit more what I was looking at, thanks. The only difference I'm after is that I want the socket to live and die with the ignition as the two fitted sockets already do.
    Not urgent - using the rear socket and a damn long lead at the moment.
    milton keynes
    ive done it on mine like you said wanted it off when ignition died, so i just spliced and solderded into the rear 12v socket had to pull the carpet up to hide the cable but looks pretty neat..
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Default Pic/Info Request
    Any of you Estate owners with OEM power socket in the nearside loadspace side liner.... any chance someone can take a peek and tell me how it is wired in please ?
    Is it a spur from the loom or a takeoff from a point on the REC ?
    I'd rather not have to bodge a connection if there is an OEM solution.
    Thanks in advance chaps / chapesses.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by Handyandy-UK View Post
    Look in the how2 section.. as ive didnt have it on mine.. but do now.. the OEM and aftermarked way )
    Engine : 2.2 Direct
  1. Strange sound in the boot area
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2014, 22:15
  2. Sub and Amp into boot storage area/flaps?
    Last Post: 29th August 2010, 20:22
  3. Boot area?
    By Messenger in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 21:19
  4. Signum boot - wet area?
    By Boba Fett in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2008, 19:58
  5. Boot Area Wiring
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2007, 18:17
