Thread: help?
    Regular Member Lee..'s Avatar
    May 2007
    Chesterfield
    Default help?
    my missis ran her astra mk4 1.6 8valve with no oil, it is noisy as hell now, anyone know how much the big ends or what ever is likely to cost
    is it worth it, its an 02 plate.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Probably cheaper to get a decent used engine to put in it instead of trying to fix that one as it would never be right
    Sodding Typical on Sea
    Sadly it might even be cheaper to get a whole other Astra for the money it would take to rebuild the engine as John says an engine would be a good starting point for cost then work from there.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as JR says ,it doesn't stop at big end bearings you could be into pistons/rings ,crankshaft,ect the list goe's on
