Thread: P0301 & P0304 misfire
    May 2008
    Tyneside
    Default P0301 & P0304 misfire
    Car is running terrible, wont go past 2500rpm, no power and then limphome. Z18XE engine on 2003 car. Codes are P0301 - cyl.1 misfire detected and P0304 - cyl.4 misfire detected. Changed the plugs and substituted a known good coilpack, no change. There is a low oil level warning up but there is plenty of oil in sump. Any help would be appreciated.
    WGAF#5
    hmmm if there is a low oil level warning its there for a reason = either sensor failure OR indeed for low oil
    is there any other faults present?
    how HAS the car been driving and what was happening just BEFORE the engine light came on ? has it been running poorly for a while or only just started?
    maybe a harness issue somewhere ??
    May 2008
    Tyneside
    Has been running poorly for a couple of days before this happened. Have had spurious oil level warnings before and put it down to sensor error, wouldn't have thought this would trigger limp home mode. Believe sometimes crank/cam sensor, maf sensor errors do not always register faults?? No other fault codes. Think you could be right with wiring issue.
    May 2008
    Tyneside
    Now have fault code P1482 cooling fan speed output circuit. Tried disconnecting battery for an hour, no difference. Also tried disconnecting the maf sensor so that ecu uses default value, running should improve slightly if maf faulty - no change. Also noted that the temp is 90 deg instead of usual 85 deg.
    WGAF#5
    i really belive with ALL of the associated issues faults that are appearing that there is a wiring issue somewhere either a water ingress or a chaffing somewhere
    May 2008
    Tyneside
    Sorted - HURRAY. After fitting plugs, coilpack, cam sensor, crank sensor, position 1 O2 sensor and checking timing, turned out to be collapsed/blocked cat. Expensive episode.
    Regular Member Kyser143's Avatar
    Bradford
    Quote Originally Posted by tridley View Post
    Hi mate I seem to have a very similar prob mine is also a 1.8 and in limp mode gives me cylinder 1 misfire changed plugs coilpack and camsensor so far but no luck. How did you clear the prob o0fn collapsed/blocked cat? many thanks
    May 2008
    Tyneside
    Had to change the cat, cost £320. If it's the cat you will notice reduced flow from tailpipe and my engine ran much hotter.
    Bradford
    Cheers will get that checked aswell did Notice a reduced flow but with engine shaking on idle thought that would be the reason but will get the cat checked out thnx
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    low fuel pressure if not said will cause issues
  1. What is causing P0301 - Misfire no 1
    By myveccy in forum Y & Z30DT Specific
    Last Post: 17th February 2013, 09:16
  2. multipul misfire 3.2 gsi p0300,p0301,p0303,p0305.
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 11th July 2012, 17:18
  3. P0304 help
    By pogvec in forum Engine & Drivetrain
    Last Post: 16th February 2012, 14:36
  4. Z30DT and P0301
    By LeeU in forum Engine & Drivetrain
    Last Post: 6th April 2011, 13:49
  5. Fault code P0301 on 3.2 HELP?
    By jamesr in forum Engine & Drivetrain
    Last Post: 26th February 2009, 17:59
opel P0301
p0301 opel vectra c
vectra c p0303
p0301 p0304 code and car limp mode
opel vectra p0301
p0304 vauxhall zafira
fluks kodp0304
vectra fault code p0301
z18xe limp mode p0304
p0301 vectra
p0301 opel vectra
z18xe timing 0304
p0304 opel vectra c
z18xe p0301
p0301 vectra c
p0301 code vectra
Vauxhall DTC P0301-04
misfire on cylinder 1 on vectra
p0304 vauxhall vectra 1.8
vauxhall vectra p0301 and p0304 code
Vauxhall P0304-0
