Thread: Engine noisy after being run
    Canvey Island
    Default Engine noisy after being run
    Good Morning All
    Wondered if i could ask for a bit of advice / knowledge please. I have a Vectra C 1.8LS 2004, when i start the car it starts first time and runs quiet, but after driving for a while the engines fairly noisy, could it be the tappets, or .......????
    Its been services three weeks ago aswell, if it makes it easier??
    Also the cars almost on 70k, when should / does the Cambelt / chain be replaced?
    Thanks for the help
    Neil
    Full Member Big Sig's Avatar
    The cambelt is 60k on those iirc.
    Regular Member Exclusive BV's Avatar
    West Midlands
    well does it sound like the tappets to you? It's difficult to speculate unless you describe the noise or post a recording
    edit:if the noise has only started since the service, did they put the correct oil in? If they used a thicker oil, it may explain top end ticking noises. An oil additive may cure it. Also did they put the correct amount in?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yup, or 6 years, which ever come first.
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    does it make a fine ticking noise when cold .and turns to a loud tapping noise when warm.
    Canvey Island
    Hi All
    Been away for the weekend, sorry for the lack of information.
    Luke you have it spot on.
    Aug 2009
    im havein the same problem mate.one person said it was that the swirl flaps were loose .but my car dosent have them.second one said it could be my injectors.im not getting no straight answer from anyone.dont want to just change the inectors on the off chances because its not cheap.if i find the problem i will let you no.if you do before me please let me no. cheers. luke.
  1. Vectra 2.0 dti noisy engine under load
    By zonerc in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:49
  2. noisy engine
    By sparkie in forum Engine & Drivetrain
    Last Post: 12th February 2012, 14:34
  3. Really noisy cdti engine
    By Shogun in forum Engine & Drivetrain
    Last Post: 8th January 2012, 22:12
  4. 1.8 vvti engine noisy
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2009, 14:43
  5. Cheap Diesel - Noisy Engine?
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2007, 09:57
