Thread: knocking noise
    Aug 2009
    aberdeen
    Default knocking noise
    I've got a knocking noise comming from the front of the car.
    It get's worse when you go over speed bumps(slowly).But
    when it's driving straight or going round corners it's fine.
    Any idea's?(vectra 56 plate 150 tdi)Cheers.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Several common issues on Vecs that cause this, drop links, front ARB (anti roll bar) bushes, radiator mounting bushes, track rod ends.
    Most likely suspect (and most common) is the drop links, will cost you about £12 each to buy and five minute job to replace them.
    PRESTON
    check the bottom of the front spring, mine was knocking and it was a bit of the spring broken off, flapping about on the pvc insulator and hitting the strut. Fine is a straight line except over bumps.
    Staffs
    I had a knocking noise caused by the spring on the brake pad not seating proplerly and basically not doing its job!
    May 2008
    manchester
    Quote Originally Posted by Ian-Highlander View Post
    These drop links? can you do it yourself or is it an expensive job to get done
    PRESTON
    relativley easy as a diy, i think theres a how 2 on it, shouldnt take a garage more than half hour to do them both, so depends on there labour rates.
    Aug 2009
    aberdeen
    Default re:
    Thanks boys,will have to check all that's posted
  1. help with me knocking noise please....
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2010, 21:00
  2. Knocking noise...
    By Gripper in forum General Chat
    Last Post: 9th September 2009, 08:12
  3. knocking noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2008, 18:16
  4. Knocking Noise?
    By akeem in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2008, 19:17
  5. 1.8ls knocking noise-help!
    By bri.gsi in forum Engine & Drivetrain
    Last Post: 17th January 2008, 18:25
