Results 1 to 10 of 11
Thread: Driver door annoying me!!Vectra C
    Jan 2010
    pwllheli
    Default Driver door annoying me!!Vectra C
    When you start to close the door there is a bang which seems to be coming from the hinge.Anyone else had this problem and what would need replacing to sort it out.It really gets on my nerves.
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    Had the problem on my old Astra? iT was the bolt holding the hinge against the bodywork, it was a bit loose? Might be the same thing?
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    http://www.vectra-c.com/forum/showthread.php?t=94599
    Have a look at this thread mate, i had to replace my door strap as it was giving a banging noise each time i opened and shut the door. Easy job to do. Hope this helps you.
    Aug 2009
    LEEDS
    my passenger front door does this
    Ireland
    Quote Originally Posted by Terry Tibbs View Post
    This is exactly the cause. Its called a door check strap and it cost me about €20 from the dealers. Easy enough job... involves removing the door card.
    Regular Member stormspiel's Avatar
    Jul 2010
    Wakefield
    Had to swap drivers and passengers on my wife's old punto. Both had ripped their wheels clean out.
    Drivers side is just starting to click on mine but the bolt seems a little loose so it may just be that.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Anyone knows how it is to change on the Omega B (modelyear 00)? as i think thats what my parents suffering from... eg. price ect.
    West
    Try greasing the mech then tightening the bolts first, if that doesn't work, whip the door card off & raplace
    Worcs/Staffs/Westmids (ish)
    ^^ Im in agreement, there's very little that the correct amount of lubrication can't fix
    Jul 2010
    Wakefield
    Punto was a complete barsteward to do, Doors had to come off to get into everything the panels were that tight. Took a good few hours to do them but well worth the effort. Originals had a crush riveted pin holding a plastic wheel in place that snapped. I changed them out for stainless bolts with nylock nuts and alloy rollers....much smoother and the doors will rust off before they break again.
  1. For Sale: Vectra-C/Signum Driver Complete Door Mirror Assembly - ULTRA BLUE
    Last Post: 10th October 2012, 16:19
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. Driver Door Mirror - Someone hit it!!
    By suresh.chohan in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2012, 14:15
  4. Driver door fault
    By oodjsparkiedeeoo in forum Vectra C / Signum Troubleshooting
    Last Post: 21st August 2011, 14:53
